Question about Motorola Mobility RAZR V3
Razor V3 will not ring with the battery cover on-take it off, call ring thru. I can squeeze the front and back covers together and it rings. Otherwise, the call are shown as missed calls. What can I do? D. Gibbs
  • 206 Answers
Just remove the covers and see for some loose connections to the ringer!! after repairing that call and check!!
reply and rate me!
Posted on Jul 15, 2010
How to change passenger seat cover on 2011 camaro?
Unless you are a very advanced DIY'er, only venture this. I have removed, HAD repaired , and replaced many seat covers over the ears, and unless you own a air of hog-ring pliers, you will play hecktiger getting i back together. Having said that, and I have not done a 2011 Camaro, (they are all similar) this is what I "see":
Disconnect any electrical connections.
From the floor, disconnect the 4 bolts holding the seat into the car. If the seat belts are threaded or attached to the seat, disconnect them.
Take the seat out, being careful not to ban or scrape anything in the process.
Lay the seat upside down on a covered bench (an old blanket will do) The underside of the seat will be exposed so you can see the springs and the Hog Ring Connections. Here is where t gets fun: with a pair of pliers in one hand (BTW- a hog ring looks like a circle of wire with sharp points on each ending. It starts as a staple, but when crimped, becomes a little circle about a half-inch in diameter) and a screwdriver or another pair of pliers, move the ring so you can see the points. You will twist each ring, and there are a lot of them, so as to open them up and roll them out of the leatherette like one would do to unhook a hook. Inside the leatherette at that connection is a long wire that is sewn into the fabric for reinforcement. These connections hold everything tight when it gos back together and must be replaced the exact same way or the new leatherette will rip and you'll have to start over or live with a bad installation.
Now continue on at each hog-ring and do this over and over and over again until the cover is loose and free of the bottom cushion. If you have adjusting handles, etc, those will also have to be removed.
Installation is in reverse.
The Hog-Ring pliers hold each hog ring neatly like a staple until it is squeezed into and AROUND the wire reinforcement at the location o each original anchoring point. It is IMPERATIVE you note the anchoring places and methods of each and every hog ring.
Once the ring is placed, carefully squeeze the pliers until it forms a ring and anchors the reinforced piece in its proper place.
Take it slow, allow the leatherette to stretch and breathe, and make sure you have it on in the right spots. As long as you don't rip anything, it should go back together as long as you are patient.
This is not a fun job for most people, but as you can "see" it can be done. YouTube has a bunch of videos on seat fixes, but this one mimics what you may encounter.
Again, having said all this, a local seat shop might be able to repair what you've got with much less effort, but if you are determined, and creative, it can be done.
04 08 Ford F150 Driver Bottom Leather Seat Cover Install
May 12, 2014 | 2011-2012 Chevy Camaro Leatherette Seat...
How to fix starter bendix gmc safari
Wow i did not know they sell starter drives any more. With starter off engine remove the two bolts that hold front bushing on the motor then remove the single bolt from solenoid to motor barrel remove barrel then armature can come out Now you will see a ring spacer that is lifted one side it faces the metal ring cover remove and tap cover back remove wire ring replace starter drive put ring on with pliers squeeze cover over wire and install last ring spacer and reassemble starter.
Nov 09, 2013 | GMC Cars & Trucks
How to transfer Motorola Razor V default ringtones
you can transfer it from your computer with the ring tones saved on the system,or via mms message sending ring tone form razor to your lg phone aso you can use blue tooyh to transfer ring tones
Dec 18, 2009 | Motorola Mobility RAZR V3
No sound coming in
mp 3 ring tone not install in moto razr v3
and moto razr v3 flashing idea
Jan 31, 2009 | Motorola Mobility RAZR V3
Motorola razor ringer
check the ring volume if it is fix to seven or not then try less no like 5 or four..
Aug 15, 2008 | Motorola Mobility RAZR V3
Phone won't ring
Try taking the back off of the phone again, remove the antenna, make sure the speaker is seated correctly and reassemble. If it is off a little bit, it won't work.
Jul 15, 2008 | Motorola Mobility RAZR V3
Razr V3 will not ring?
that means the phone's main-board is faulty so you both need to have the mobiles exchanged.
Mar 07, 2008 | Motorola Mobility RAZR V3
Replace razor screen / cover
yes, but you need the rigth tools, google v3 razr repair. just buy new razr housing on ebay. it'll look like new
Oct 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
