Question about Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK THE FILTER APART, CLEANED IT, PUT IN NEW DE AND IT STILL SPIKES?
  • 106 Answers
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Posted on Jul 15, 2010
Message constant check screening. screening is clean how do i fix model 110-82822-102
There is a pressure switch or an electric eye that is plugged with lint or burnt out. Who makes that machine?
Dec 01, 2014 | Dryers
Water filter keeps popping out
Too high of pressure I the water supply. The lines may have frozen up. If you can I would defrost the freezer and leave the water on and try to cycle it through until you get good water flow. Then throw the filter back in and see how it gos. Good luck
Sep 09, 2012 | Frigidaire GLRS264ZA Side by Side...
Pressure in the filter, flow of water not good
take apart clean grids use TSP to degrease then put back in an recharge with DE
Jun 24, 2012 | Hayward EC-40 DE Pool Filter with pump
I get DE back into my pump strainer and I only can filter for 2 to 3 hours before pressure is up to 20 to 25 lbs and I have to use bump handle to start filter again with results
The de coming back into the pump isnt anything serious, there may be a small air leak causing the water in the filter to drain into the pump.
As far as having to bump every couple of hours... is the pool really dirty?
Is your pressure gauge broken? Turn off the pump, does the gauge drop to zero? Alot of times they dont drop to zero, so when you hit 25psi it may really only be 15. Happens alot actually.
If pool is clean and clear and the gauge is fine... have you ever taken apart the filter and cleaned the de fingers? If not, i would take it apart, rinse all of the fingers and then let them soak over night in a filter cleaner solution. This cleans them much better then a plain garden hose spray. After they soak, spray them down again, add new de and you should be good to go....
Aug 15, 2010 | Hayward EC-40 DE Pool Filter with pump
Pressure increase over the red line on pressure gauge while we were away for a weekend. Now pool is cloudy white. I am assuming this is DE. Back washed and cleaned filter twice. However, after running...
When the pressure goes up, try this. Pour some muriatic acid in the skimmer. (about 1/2 bottle) Let pump run for a little bit,(long enough for acid to get into filter)then shut off pump for 5 minutes or so. If pressure goes down to where it should be when it's turned back on, it needs to be disassembled and cleaned and then acid washed.
Jul 28, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Anthony filter system faulters after short while of running
If you have alge in your water it builds up in the filter and stopps it up rite away. You will need to take the filter apart again and hand clean it out again. but you will need to super chlorinate the water and kill all the alge before you start the pump or it will plug again. If you run it like this for any amount of time it will crush the grids, so be sure you kill all the alge.
Oct 13, 2009 | A.B.S ALADDIN GO-KIT #7 ANTHONY POOLS 2"...
My 85 s10 blazer keeps pushing the seal out of the oil filter and puking out the oil. ever heard of this?
yes your oil pump pressure relief valve is stuck the oil pump has to come out.it is building way to much pressure.
Mar 29, 2009 | 1985 Chevrolet S-10
Open Questions:
See all Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP Questions
Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
213 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
