Question about Toro Lawn Mower With Toro Power Tools
I have a Toro lawnmower model # 20676. The mower has 3 drive gears. The problem I am experiencing is when I engaged the drive gear in to second gear. It engages and runs fine for a few minutes then stops and slips and does this intermittently and continues to do this endlessly. However It does not do this when engaged in first gear.....operates fine. What is causing this and what part do i need to replace to correct this problem? Any help is appreciated. Thanks!
jmgldsmth
  • 2005 Answers
SOURCE: Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
Posted on May 20, 2009
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
sounds like the transmission engagment lever is broken or cracked. if you can reach the lever see if it has play when the cable is tight. you will need two people one to hold the lever and one to check the lever. easiest way is to invert the mower and have someone hold the lever on the handle. do not try this wioth mower running. the lever should be tight with the transmission lever engaged.another note here the clutch lever will not feel solid but kinda spongy. usually caused by overtightening the cable.
Posted on Jul 07, 2009
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
  • 133 Answers
SOURCE: toro self propelled will not move wheels. Checked engaging keys
Remove the front wheels and see if the cogs that are molded into the wheels are stripped. If they are stripped out that could be where the noise is comming from.
Good Luck let me know if this helps.
roundo4
Posted on Aug 14, 2009
Toro timecutter starter
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
May 05, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
Have a toro lawnmower mdl #20012 front whell drive. When I engage the system it makes a grinding sound & when I take the weight of the wheels it runs smooth. Seems like a gear but not sure. Could it...
Some have gear in each wheel. Remove wheel see if plastic in wheel is worn out. Home Depot or Lowes carries some replacement wheels. Lawn mower repair shops sell them also.
Aug 22, 2012 | Toro Power Lawn Mower
I am trying to install a toro front wheel drive gearbox and have all the washers mixed up
Going from the inside out. You will need the round washer without a key, then a washer with a key, then the e clip, then another washer with a key, install the spring .. key .. and the drive gear. After that it in one more washer with a key and the last e clip. Only one side will use the washer without a key.
This should get you back in "gear" :)
Mar 23, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I bought a Toro rear wheel drive lawnmower last May.I have never had any problems with it until now. the left rear wheel sticks. With the power off, I can roll it a little and it will stick and then I can...
The gear drive is probably just a little dirty. You can clean and lube the gears by pulling of the rear wheels and then remove the rear drive gears. Clean them and the axle and reinstall. Be careful to reinstall in the same direction as was removed. A smearing of axle grease in the axle and inside of the drive gears should take care of this.
Also remember that TORO mowers come with a 2 year warranty. Go to www.toro.com to find your nearest servicing dealer.
Nov 04, 2010 | Toro Lawn Mower With Toro Power Tools
I have a self-propelled Toro Personal Pace lawnmower, Model 20022. Both rear wheels engage and rotate when I lift the rear wheels off the ground, but when I put the mower back on the ground, the right...
Routine maintenance is required on the drive gears on these Toro mowers and Toro doesn't tell anybody. Put a block under the rear end to lift the wheel off the ground. Remove the wheel. You will see the drive gear. VERY IMPORTANT: take good notes, pictures, etc..when dissasembling. Remove the outer snap ring retainer from the axle shaft. Next should be a thin washer. Remove the washer. Pay very close attention to the gear, as it has to go back on in exactly the same direction. Remove the gear. There is a slot in the axle shaft. Rotate the axle to have this slot pointed up. In the slot is a small key (rectangular piece of metal), remove the key. Under this key is a spring. It, and the key, is stuck in the axle slot, therefore not allowing the gear to drive the wheel. Dig out the key and spring, clean them and the slot. Put a dab of axle grease in the slot and reassemble. In my shop, this is part of a mower tune-up, and is recommended every 50 running hours. That is usually every other year for the average home-owner.
DO NOT TIP your mower over to do this repair. Mowers are just like cars, they like all 4 wheels to stay on the ground. Tipping a mower over can/will cause fluids to go places they aren't supposed to go.
This is a relatively simple repair and can be done with basic mechanical knowledge and basic tools.
Do the other side too, it needs it.
Sep 11, 2010 | Garden
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Model #20064 wheels do not turn when you squeeze the bar to engage them. The pulley under the plastic guard spins but not the wheels.
Have you observed what happens under that plastic guard when you squeeze the bar? Do you feel any resistance at all when you sqeeze the bar? The reason I am asking is because there are a number of reasons why this is happening. The drive gearcase is actuated by a spring loaded arm that engages the drive gear to the spinning gear attached to the pulley. A good way to test this is to disconnect the spark plug, raise the mower just enough to lift the wheels off the ground, engage the arm and spin the pulley by hand; if the wheels move then it most likely is the drive cable...if the wheels do not move, it is the gearcase. On a rare occasion it could be the belt is old and stretched out, you can test that easily as well...start the lawnmower, raise the wheels by pushing down on the handlebar and engage the drive by squeezing the handle, if the belt is stretched out, the pulley will move intermittently or not at all.
Hope this helps!
Nov 05, 2009 | Toro Lawn Mower With Toro Power Tools
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
138 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
