Question about Toshiba Satellite M45-S331 Notebook
Partial blackout on Screen
The screen on my laptop has been acting very strangely for the past few months. A few months ago, the right side of the screen started to get a little bit fuzzy with some neon-colored striping, but typically these stripes would go away after a short period of time. Eventually, the stripes would last longer and I would have to open and close my laptop a few times in order for them to go away. Now I have a thick black stripe up the right side of my screen that will not go away. It is about 2.5 inches wide.
While my laptop is still fully functional as long as I keep my windows in the part of the screen that I can see, the problem is somewhat inconvenient and I would like to have full use of my screen again. Is something that can be repaired or do I likely need to replace something?
Thanks,
Betty
  • Anonymous Oct 06, 2008
    Hi!
    I have the exact same problem. Does anybody have a solution for correcting this?
    Thnx!
    Problem Solver:
I have the same laptop, and though I havent had a black out problem i do have screen burn or a discoloration in the lower corners of my screen. I was told that It was due to this model's overheating issue and that I would have to replace the screen.
Posted on May 21, 2008
LG 55LF6300 Black spot and picture freeze every few seconds
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 03, 2017 | LG Televison & Video
Gateway nv55c
it maybe as a result of partial contact. When i say partial contact, i mean the screen or its flex it has loosed contact or not properly fixed in its right position.
You need to have it checked for proper diagnosis.
Good luck.
Aug 21, 2014 | Computers & Internet
How do i get the OSD lock to stop flashing on my screen?
mcadams_alic, Mostlikely a problem inside unit. After visiting this web site: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ you may then understand why your unit is acting "strange"!!! Your lcd monitor isn't any different than any other brand in it's basic design and operation. When very strange stuff starts appearing on the screen of any CCFLback-lit lcd monitor the first place all lcd technicians would look will be the monitor's "switch-mode-power-supply!!!! hope this helps. 12fixlouie
Jun 08, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
Fuzzy line going right down right side of Sony Laptop VGN-CS26g
The pixels inside of the LCD are going bad. Your screen is going to need to be replaced. When pixels in screens go bad it usually turns colors or gets fuzzy after it heats up.
May 14, 2010 | Sony VAIO VGN-CS260J/P Laptop
M50 SCREEN TOTAL BLACKOUT
i think there may be inverter problem.
Mar 07, 2009 | Toshiba Satellite M50 Notebook
Number issues on screen
do you have num. lock on? mine did the same a few days ago and that was my problem
Dec 27, 2008 | ASUS Eee 4G Notebook
Screen
I have the same problem...my Aspire 5630 goes black about once or twice a day and I have to re-start computer...then it wants to disk-check. The fan makes a lot of noise before this happens...could it be the fan overheating?
Apr 20, 2008 | Acer Aspire 5630 Notebook
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
Monitor blurry or black
The problem could be with the LCD or the Video chipset. Either repair is expensive. I would figure about $150 in labor plus part cost. You can try ebay to get an idea of the part cost.
At 4 years I would be leaning towards purchasing a new laptop.
Dec 30, 2007 | IBM ThinkPad R40 2897 Notebook
Panasonic PT-47wx53 screen converged to middle of screen
This sounds like a classic High Voltage problem. Yes the two issues are related. Something in the High Voltage circuit has failed and originally caused the increased size. If you described the problem to the warranty people I'm surprised that they didn't recognize the problem and fix it under warranty. Now you have a short or partial short in the same circuit causing the fault (light blinking) after a few minutes. This problem will not cure itself. As I have told customers in the past "Electronics are not human and will not heal themselves". Maybe in the future, but not yet. You need a technician and it should be covered under warranty if things are as you described. I would recommend calling Panasonic customer service. They are usually a very good customer oriented company.
Nov 05, 2005 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba Satellite M45-S331 Notebook Logo
340 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
