Question about Honora Watches
MY DUGHTER SENT ME AN HONORA LEATHER WATCH for a gift. The watch arrived in good condition -- it is running, however the time is not correct -- and I do not know how to set it. There are no instructions enclosed. The watch is 1ZA2F641PP06567422 The tag on the watch reads :- Honora SS Traq Mch H/Rd Dial I would appreciate gettting assitance in setting this watch or recieving instructions how to set this watch to EST. There does not seem to be a stem on the watch for setting it.
  • 6,993 Answers
since there is no stem for the watch setting, there is no way you can reset the watch.
I would advice that you take the watch to a repairer to fix it for you.
Good luck.
Posted on Jul 15, 2010
Is there a battery in a honora stemless watch
Yes. A jeweler or watch repair service can change it.
Feb 23, 2015 | Honora Watch
Which is a better gift for my boyfriend? Please do help. :)
the swiss watch. also a new fishing rod and a case of beer
Apr 06, 2017 | Timex Indiglo Watches
I cannot set the time on my Honora Floating Pearls watch. When I press the time setting button, nothing happens. The watch is working and so is the battery.
Use the "******" part of the buckle to press in the dimple in the center of the back of the watch..Juse did on the on I got from Rue La La & that worked.
Sep 27, 2011 | Honora Watch
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
I just got the watch as a gift on x-mas it stopped working yesretday while I was wearing it mens giovanni self winding I pushed the second hand button A and nothing I didn't drop it or get it wet or...
Having read the limited instructions for this watch, it does not seem as though there are many options available!
If you haven't already done so, try pressing A again.
If nothing happens, press B
It could be that the watch has simply stopped because it needs re-winding (it depends on how long it had been running when you got it.
To wind the watch swing it gently from side to side for a few minutes. ( some makers say swing it 200-300 times!).
If you still have no joy, then contact the makers help line; go to http://www.raymond-weil.com/EN/Swiss-Watch-Company/After-Sale-Service.html to find your nearest service center.
Jan 03, 2011 | Raymond Weil Don Giovanni Chronograph...
Honora watch does not have stem - how do you set the time?
This is a newer kind of movement. All you need to do is take the stem from the watch buckle and press & hold it into the circle at the center of the back of the watch. This will cause the hands to start moving and the movement to start. Once you get to the correct time, please remove pressure and the watch will be set! I hope this helps!
Aug 14, 2010 | Honora Watch
The glass cracked in my Honora, how can I get a new glass?
if you are in the USA:
if you are in Europe:
Search Results AQUALAND WATCHES § ROLEX DEALERS IN LONDON HONORA WATCHES ... Day shipping to uk france greece brazil germany australia. ... 1350s aqualand watches no laser cooling of astronomers. Indicating eclipses or inform ...www.pokerwebtown.com/uuiwqd/aqualand-watches.html -
Jul 31, 2010 | Honora Chronograph Watch Black
My Quartz sports watch works, loses time, had three months, .
Sounds like battery is failing. Time to replace it! :-) Sears stores usually have a watch repair counter...or find a reputable watch repair business. (Even if the watch is new...its still possible the battery could be failing because you have no way of knowing when it was originally installed! They typically last about 2-3 years depending on age and condition of watch!)
Jan 09, 2010 | Timex 27191 Wristwatch
Sunrise/Sunset Time and Moon Phase wrong on watch!
Just in case you're still interested in a solution. Your watch uses a geographical location and the current date to estimate the sunrise and sunset times. While the date (and time) information is, most likely, set on your watch correctly, you, probably didn't specify the geographical location (latitude and longitude, as well as the GMT correction for your time zone). Having setup correctly these parameters you'll enjoy the precise sunrise and sunset time. Good luck!
May 29, 2009 | Casio Watches
How to set a Honora chronograph watch
You have to upload here all details of the watch: model, ref. number. Movement number and good pic would be very helpfull.
Dec 20, 2008 | Chase-Durer Typhon Chronograph White Dial...
Watches Logo
190 people viewed this question
Top Honora Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Honora Watch Expert? Answer questions, earn points and help others
