Question about Coffee Makers & Espresso Machines
Hi, no water through e61 group head ?
I have water to the E61 group heads and have swapped the solenoid for a new one on both (2) groups and still no water through the group head....any tips ?
    President:
  • 1,618 Answers
Check the metering jets and filter on the top of the group heads.
Posted on Jul 16, 2010
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
Direction replacing goup solenoid
As you have put it water flows from boiler to group head so the arrow on the solenoid should be this direction.
Aug 15, 2012 | Pasquini Livia 90 Espresso Machine
Hi, I have a kitchenaid artisan espresso machine model 5KES100. The espresso boiler is not producing any water, just some steam or nothing at all. I have replaced the pump, but there is no water being...
I would remove the filter grille from the group head (Philips screw) and then clean the surface behind that sufficient that you can see and then unscrew the 2x Allen head bolts holding the aluminium puck in place. The puck will be frozen in place even after bolt removal but easily broken away by levering it with a large screwdriver. You can lever against the bracket that carries the group handle. Once you have the puck out scrape it clean and buff it up with a wire brush and clean out the 4 holes through the puck where the water is supposed to pass through on its way to the coffee. Check if the group seal has gone hard and replace it while the puck is out if it has. When done reassemble it. Blockage of those 4 holes is a very common cause of zero flow. It's doubtful the solenoids will be faulty but not impossible. It is possible that a solenoid coil has gone open though, testing and comparing with a meter or just swap the coffee and steam coils over will prove/disprove that one.
Jul 10, 2017 | KitchenAid Artisan
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
The water stopped coming out of the group head so I took the damn ting apart. Espresso parts everywhere... I can't figure out how the water flows through the boiler then on to the group head. Any advice...
Hi
It was probably your 3 way valve. Its located behind the panel below the group head. 2 screws and it slides to the right only. Remove the black nozzel then the #14 nut on the bottom of the 3 way. Solenoid will slide off. There are 2 screws holding the 3 way on. Install the new 3 way in rreverse. and you will be good to go.
Dec 30, 2010 | Rancilio Silvia Espresso Machine
My e61 group head on my Diadema UNICO Splendor exhaust port probs
There might be one of 2 things going on,
1- the exhaust tube is blocked.
2- one of the three gaskets in the group is on backwards.
Jul 24, 2009 | Coffee Makers & Espresso Machines
Installed new ulka vibrating pump in my Rocket E61 (Giotto) but the pump won't prime.
If when you installed the new pump and turned it on and made loud vibrating sound but not pumping any water through what you need to do is when you turn the pump on open up your steam valve turning the steam knob. Usually it is just an air lock and this should allow the air out and water to flow through. When water comes out of the steam arm, close it off and water should then come out the group head as normal. If you try this and nothing happens you either have a build up of scale which you just need to try to flush a good descaler (Puly Baby Powder) through your machine or the pump you got is faulty.
All the best
LaPavoniBoy
Jun 10, 2009 | ECM Giotto Espresso Machine
No water coming out of the group head?
Your problem is either the brew solenoid or the brew switch.
Feb 09, 2009 | La Marzocco FB-80 Series 3 Groups Coffee...
When I pull the lever to make an espresso it takes about 10 seconds for water to come out. It's as though all the water in the boiler (or heat exchanger?) drains out when I dont use the machine for about...
Tank fills automatically with level electrode on top of boiler. Same punp that brews your coffee will top up the tank. Electrode full of scale - no water in tank. The boppom of group has drain exit. Fully normal to have a bit water to drain out. tale apart and clean manually! Nothing to be afraid of. take photos as it can get tricky to get all pcs back after mayor overhaul. Larger commercial machines have the drain outlet covered behind a vertical wall. You don't see the water but the E61 group is identical!! ///Olev
Nov 01, 2008 | ECM Giotto Espresso Machine
Coffee Makers & Espresso Machines Logo
204 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
