What do I need to do to relaces a door hinge on hotpoint model wd63 washing machine
  • 11,896 Answers
Http://www.watchdoit.com/how-to-videos/How-To-Replace-A-Washing-Machine-Door-Hinge-AEG-47883
Copy and paste this link in your internet address bar to watch the video on replacing the hinge.
To remove the door hinges, you will need to remove the bolts, then the for the springs you just take the bottom front cover off of the dryer.
There are a couple clips towards the top corners that you can release with a flat blade screwdriver.
Once you get that bottom front cover off you will see the springs and can disconnect them from the hinge. Then remove the hinges
Posted on Jul 23, 2010
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
I have bought a new door hinge for a hotpoin wd63p washer dryer but was wonderig do you have to take the front of the washing machine or the rubber
hi from uk easiest way is to turn off/remove water supply hoses disconnect power then remove top screws from rear panel(these also secure top panel if yo look ?) then lift rear of top panel slightly and pull back/then lift off you now have access to rear of front panel where door hing is secured by 2 screws from the front of panel/hing into a metal plate theaded inscrew door from plate whilst you hold plate thenremove door with hinge assy you will now see the inner plastic cover of door is secured remove this cover to access hinge screws renew hinge and whilst door is at this point might as well lift glass window and clean any **** around the edge ? reassemble in reverse to strip down hope this is clear enough for you ? good luck
Nov 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Broken Hinge
Hello jonckenny,
I wasn't able to track down your specific part but by using this link and speaking with their parts rep, thsy should be able to assist you.. http://www.pcappliancerepair.com/cgi-bin/partsearch.cgi
Hope this helps.
Regards,
Rick
Dec 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd63
take door off. outer porthole is just clipped into frame. gently prize out with a small screwdriver
Mar 04, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
