Silly question, but is your friends phone Qi supported? Normally a red flashing light means that there is an error in charging. It will blink blue when charging and steady blue when fully charged. I am not quite sure what it's erring for, however, red should only blink when there is a problem, so I would have to say that it is having problems and not charging properly. What is causing that I'm not sure, I might trying Googling your particular model of charger and see if they have an FAQ that will explain the lights. This is the best I can offer at this time. Good Luck! Maybe someone else has encountered this and can go a little more in depth.
The cell phone maybe faulty. Take it back to where you purchase it for a replacement or repair as it wuold be still under warranty. Do not try to fix it yourself because you may void your warranty.
hold the button down and it will change to blue, then you need to make sure your phone is connected to the speakers bluetooth. then when you play music off you phone it will come out the speaker. the red light is for aux mode - where you plug your phone or ipod in.
I am having the same problem with my KX-TGA234W. One day the screen just went blank, so I changed the battery, but it still is blank. I hope that someone can help both of us.
There is a tiny little rectangle in the upper right corner of the main screen on the handheld. It's divided into 4 sections and each section lights up separately as the amount of charge goes down the light moves to the right. Fully charged all four sections are lit.
The red light indicates its charging. My guess is that the battery is dead and will nto hold a charge. This is an older model phone and the lives on the batteries is 1-3 years at most.
