Question about Refrigerators
Fridge not working
My bosch nofrost fridge freezer is flashing E2 for the cooler, the frezzer is working
  • m1956o Apr 21, 2008
    Can i fix this sensor by myself, is it going to be costly if i get enginer in to fix it, thanks
    Thank you for help refritech, appreciate it
    Scholar:
  • 149 Answers
Check the owners manual if not im suspecting some sensor has to be defective.
Posted on Apr 21, 2008
  • Alexander  Figueroa
    Alexander Figueroa Apr 21, 2008
    if you can find the location defective sensor and replace it yes, it can be replaced it's a simple job but you have to find the trouble code in owners manual or call the technical support hot line for that manufacturer of fridge. i can't tell you cost because I've haven't worked that brand before but it shouldn't be costly if its a sensor.
    no problem
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Zanussi nofrost fridgefreezer, fridge working but freeze not, only just 16 months old
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Jul 09, 2011 | Zanussi Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
E2 fault on Bosch kgu3201
Dear Sir,
It's a thermistor error, the internal evaporator one... but disconnect the fridge and freezer ones first in turn to see if the error changes. If it is the internal one, you should see an arrow impression on the paper covering the insulation which marks the spot to dig(at the back of the freezer.) Usually this error occur when water ingresses the push on tags, shorting out the thermistor.
Now the bonus... 9 times out of 10, you don't need to buy a spare, as there will probably be nothing wrong with the error giving thermistor. Remove and fit the fridge thermistor in the place of the internal one... clean and dry the internal one you removed and refit it inside the fridge.
You will need to repair the insulation with two pack brown foam insulation and foil tape. deffinately this solution solves your problem.If you have any problem regarding this issue post comment more information about the problem.we will glad to assist you
good luck.
good luck
Aug 26, 2009 | Bosch Refrigerators
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
About the mini retro portable cooler/warmer
Hi Charlene,
Open the freezer and see if it needs a good defrosting. I know you may think you bought a Frost free Fridge, but if something goes wrong with the forst free system, It can frost up. If it is Frosted , Turn the Fridge off and use a hair dryer for about 30 minutes to melt all the fost and dry up the frezzer compartment,  It is imprtant to dry u the Freezer compartment.  Hope this helps you.
Oct 18, 2007 | Refrigerators
Bosch Cooler is broken
im taking it that the cooler you refer to is actually a general fridge. if its not working, it is either your th/stat which has not reset or if not, assuming your fridge is an auto defrost, look behind the freezer and locate the timer. you should see a plastic knob plus/minus in the middle of the timer. turn the knob and listen if refrigerator comes on. if not call a tech.
Feb 20, 2007 | Bosch KIL24443 Top Freezer Refrigerator
Bosch Fridge Freezer KGU32
E2 indicates failure or out of tolerence evaporator sensor which is foamed in and not replacable. The only repair posibility is replacement of the electronic control board which now ignors input from the sensor
Aug 11, 2005 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
284 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
