Question about Brother IntelliFax-4100e Fax
CANCEL PRINT JOBS
ALTHOUGH IT READS NO JOBS REMAINING, IT CONTINUES TO PRINT JOBS IN MEMORY FROM MONTHS AGO. HOW TO I CANCEL THIS? IF I PUT PAPER IN, IT PRINTS NON-STOP
MUKHTAR
  • 2022 Answers
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Posted on Oct 06, 2007
SOURCE: out of paper light
I've been stuck with a flashing red paper light for a while. The printer could print from the manual tray and could also print test or diagnostic pages.
So I thought it might be driver related, and indeed it was.
There's a nasty setting in the printer properties that makes the printer go woo-hoo. So go to printer properties > tray settings. Check the "paper size" of "Tray 1". If it's set to "undefined", change it to your corresponding paper format. Click Update, Apply. Now print happily.
I still wonder why that setting magically changed. Hope this helps someone.
Posted on Nov 11, 2007
  • 5 Answers
SOURCE: Print faxes in memory
Slam it with your Fist, Hard! Kick the piece off the desk and jump up and down on it. **** on it!!
Posted on Sep 22, 2008
SOURCE: "Unable to Print 50" BROTHER MFC-440CN
congrats! You just bought yourself a brand new printer! I just phoned the company and apparently if you have a teeny tiny paper jam and a Unable to print 50 pops up ... you just bought yourself a new machine, that particular message means your machine was damaged thru the course of your paper jam. The average cost an hour to fix it is $85 so its better to just buy a new one.. What a piece of ****. :-(
Posted on Oct 07, 2008
  • 121 Answers
SOURCE: Cannon Faxphone L75- need to cancel current fax-print job
You can't. Just print it out.
Posted on Jun 22, 2009
OKI 461 error C531dn LED Colour printer.Says the paper is wrong but it isn't! It's suggesting I have to load A5 paper although I am printing A4 and it's an A4 tray. Done loads of printing before.
I suspect you have sent the job to the MP ray and it wants you to put paper in it. Cancel the job and go back into the driver and make sure paper source is set to the cassette.
Aug 17, 2017 | OKI Office Equipment & Supplies
How to Cancel Printing in a Brother HL-2135W printer
Start by pulling the paper tray out to stop further pages being printed without jamming the printer up.
Then go onto your print queue on your computer and delete the job that is printing 50 pages.
If it dissapears then put the paper tray back in and it may print out the last page or two that were in the printer buffer.
If it does not dissapear from the print queue then turn the printer off and try to delete the job again.
Once you have ordered the job deleted then you can turn your printer back on and put the paper tray back in and allow it to continue. It should only print out the last page or two and then the job will dissapear
Sep 15, 2014 | Brother Hl-2135w Compact Wireless Mono...
I need free support to empty memory of brother HL-2140 printer
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
I hope this helps.
Dec 27, 2012 | Brother HL 2140 Laser Printer
Help please, I've a paper jam. how do you open the printer ??
Clear the jam from the back of the All-in-One Follow these steps to clear the jam from the back of the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Press in the tab on the left side of the rear door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear doorc00652174.gif
  3. Gently pull the paper out of the rollers.
    CAUTION: If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Connect the power cord to the back of the product.
  6. Press the OK button to continue the current print job.
    NOTE: The print job might cancel instead of print. If this happens, reprint the document.
  • If the issue is resolved , you do not need to continue troubleshooting.
  • If the issue is not resolved , continue with the steps in this procedure.
Clear the jam from the front of the All-in-One If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front.
CAUTION: Remove the paper jam carefully because it is possible to damage the product when removing paper from the front.
  2. If necessary, pull the input tray down to open it, and then lower the print cartridge door. Figure 2: Print cartridge doorc01491485.gif
    CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams might occur.
  4. Close the print cartridge door.
  6. On the control panel, press the Start Copy Black button (c01495311.gif ) to continue the current print job.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
For more info, you can click the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00651302&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=1141647
Feb 15, 2011 | HP Photosmart 4180 All-in-One Printer
I printed a report from the internet a couple of days ago. Now my printer continually prints header information (one line) over and over. It won't stop! If I load the paper tray, it immediately starts...
Take the paper out, go to control panel - printers, open your printer's folder, and choose from the menu Purge all print jobs. If you have some kind of printer status monitor, go there and look for any job that's pending, and try to cancel it. Now turn the printer off, on again, and insert paper - it should be over.
Nov 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
Job won't cancel
if I was you I would uninstall the driver and install everything from scratch.That should solve the problem
Jun 17, 2009 | Dell 5110cn Laser Printer
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
Canceling faxes in memory
No can do. Sorry.
Let them print out.
Oct 10, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Brother IntelliFax-4100e Fax Logo
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
