Question about Brother Office Equipment & Supplies
Instructions on machine: "clean corona on drum" No instructions in manual on how to remove toner cartridge or the drum. I pressed the release button, and the toner pops up, but it is still locked in on both sides. How do I remove the drum to clean a corona, & where is this corona on the drum, & how do I clean it? Model DCP 7030 Roy Lewis New Germany Nova Scotia
  • 4,924 Answers
Http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=dcp7030_all&Cat=7
Here on this link you have all you need directly from Brother support site ..just click them one at the time cause there is a link for how to remove the drum ..and about how to clean the corona wire..
Posted on Jul 15, 2010
How do I clean corona units on Minolta 1081 copier?
Gregory, First remove the drum unit. Then remove the Charge unit. located about the drum on the drum cartridge (Not Inside the Machine) Then remove scortron grid push the front in to release you then have access to the charge wire this model may have the Charge comb type be care the combs are sharp if they are wires be gentle and use a eraser to gentle clean the wires they are very thin. During the copy process the wire/comb applies a HV charge on the drum prior to the image from the mirrors being place on the drum before the paper arrives underneath the drum.
Jan 02, 2015 | Konica Minolta Minolta EP 1081 Laser...
Corona wire problem
Hi, you can clean the corona wire easy, just follow those steps:
1) Turn of printer power and unplug all cord including phone cord.
2) Make sure the scanner is closed, then lift open the top cover by its handle.
3) Remove both the drum unit and toner cartridge assembly for the color desired to be replaced.
4) With the drum unit removed, push down the GREEN lock lever to remove the toner cartridge.
5) Slide the GREEN tab left to right several times to clean the unit's primary corona wire.
6) Before installing new toner cartridge, shake it from side to side to distribute toner.
7) Remove protective cover from cartridge.
8) Insert cartridge into drum unit until it snaps in place.
9) Ensure that you are inserting the correct color toner cartridge into its proper place and then slide the drum unit into the printer.
10) Close the top of the machine and then reconnect all cords; turn on power to ensure proper installation.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Says drum error, see troubleshooting maitainance chapter in user guide. Don't have a users guide. Printer is brother mfc-7340
I have this manual for you. I can be reached at LBrown18062@hotmail.com
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&type2=-1&prod=mfc7340_us_as&c=as_ot&lang=en&flang=all
Drum Error - The corona wire on the drum unit needs to be cleaned.
Clean the corona wire on the drum unit. (See Cleaning the corona wire on page 122.)
Cleaning the corona wire: If you have print quality problems, clean the
corona wire as follows:
a. Turn off the machine's power switch.
Unplug the telephone line cord first, disconnect all cables, and then unplug
the power cord from the AC power outlet.
b. Open the front cover.
c. Slowly take out the drum unit and toner cartridge assembly.
CAUTION: We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
To prevent damage to the machine caused by static electricity, DO NOT touch the electrodes shown in the illustration.
d. Clean the corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times.
CAUTION: Be sure to return the green tab to the home position (a) (1). If you do not, printed pages may have a vertical stripe.
e. Put the drum unit and toner cartridge assembly back in the machine.
f. Close the front cover.
g. Plug the machine's power cord back into the AC power outlet first, and then reconnect all cables and telephone line cord. Turn on the machine's power switch.
Dec 31, 2010 | Brother Office Equipment & Supplies
There is a massage in red that reads drum error
Brotherstrongly recommends that customers do not use generic drum units and/or tonercartridges, or refill their Brother toner cartridge. Each Brother laser printeris designed to work at pre-set temperatures that are matched exactly to each ofour individual toner formulations. Each individual component is designedto work with the other to ensure quality and reliability. Using non-Brothersupplies may affect the hardware performance, print quality, and machinereliability. The Brother limited warranty does not apply to any problem that iscaused by the use of unauthorized third party drum units, toner cartridges, ortoner. Turn off the printer power switch. Press thefront cover release button and then open the front cover. Hold the green handle ofthe drum unit. Lift the drum unit up and then pull it out until it stops. Hold the handle of thetoner cartridge and pull it out of the drum unit. Repeat this for all the tonercartridges.
    • I recommend that you place the toner cartridge on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
    • DO NOT put a toner cartridge into a fire. It could explode, resulting in injuries.
    • Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    • To avoid print quality problems, DO NOT touch the shaded parts shown in the illustrations.
Push to release thelatches of the white corona wire cover (1), and then open the cover. Clean the corona wireinside the drum unit by gently sliding the green tab from left to right andright to left several times. Be sure to return thetab to the home position (1). If you do not, printed pages may have avertical stripe. Close the corona wirecover. Repeat steps 4-6 to clean each ofthe remaining corona wires. Hold the handle of the toner cartridge and slide the toner cartridgeinto the drum unit. Make sure that you match the toner cartridge color to thesame color label on the drum unit, and make sure that you fold down the tonercartridge handle (1) once the toner cartridge is in place. Repeat this for allthe toner cartridges. Put the drum unit backin the printer. Close the front cover ofthe printer.
Nov 16, 2010 | Brother HL-4040CN Laser Printer
Have a black line on all my scanned files, runs the length of the page, about 1 1/2 inches from the left edge.
To determine if the vertical lines appearing on your printed documents are related to a printing or scanning issue, print a test page by pressing MENU, 4 (Printer), 2 (Print Options), 3(Test Print) and COLOR START.
If the vertical lines appear on the Test Print continue to Procedure A:Cleaning the Corona Wires Inside the Drum.
If the vertical lines do NOT appear on the Test Print continue to Procedure B: Cleaning the Scanner Glass.
Procedure A: Cleaning the Corona Wires Inside the Drum:
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
A1. Power off the Brother machine using the power switch located on the right side of the machine.
A2. Press down on the front cover release lever and open the front coverby pulling it towards you.
A3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
A4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
A5. Lift the white plastic corona wire cover by lifting the tabs locatedon the right and left side of the cover.
A6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
A7. Close the corona wire cover.
A8. Repeat Steps 5 through 7 to clean each of the remaining three coronawires.
A9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
A10. Push the drum unit back into the machine until it clicks into place.
A11. Close the front door and power on the Brother machine.
A12. Print a test page by pressing Menu, 4 (Printer), 2 (Print Options),3(Test Print) and Color Start.
B1. For safety reasons, power the Brother machine Off using the power switch located on the right side of the machine.
B2. Lift the Document Cover and clean the following with a lint-free cloth moistened with a non-flammable glass cleaner:
a. Run your fingertip over the scanner glass of the flat bed to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris. (Caution! Do notpress down on the glass very hard.)
b. Run your fingertip over the scanner glass on the left to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris.
c. The white plastic pad located on the underside of the Document Cover
d. The white plastic pressure bar located to the left of the white plastic pad.
B3. Close the Document Cover.
B4. Test the machine by making a copy of a blank sheet of paper using the ADF (Automatic Document Feeder) and a copy using the Flat Bed.
a. To make a copy using the ADF, place the document face UP in the ADF, press the COPY mode key located below the LCD display and then COLOR START. If the problem continues,repeat Steps 2b and 2d at least 3 additional times.
b. To make a copy using the flat bed, lift the Document Cover of the flat bed, place the document face down on the scanner glass (make sure the ADF is empty) and close the Document Cover. Press the COPY mode key located below the LCD display and then COLOR START. If the problem continues, repeat Steps 2a and 2c at least 3 additional times.
Oct 29, 2010 | Brother MFC-9440CN Laser Printer
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
How do we clean the drum
from the brother website...
Description of Problem 100000015035
How do I clear the message PLS CLEAN DRUM from the display?
Description of Solution 200000019400
Dust or toner on the corona wire may cause this error message to appear on the display. To clean the corona wire, follow the instructions listedbelow.
1. Open the front cover (below the paper ejection tray) by pulling the taps on the left and right side of the unit towards you.
2. Lift the drum unit slightly and pull it out.
3. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner.
4. Clean the corona wire inside the drum by gently sliding the blue tap (located on the top left side of the drum unit) from side to side 7 or 8
times.
5. Return the tab to the home position (left side of drum). It should click into place. NOTE: If the tab is not at the Home position, printedpages may have vertical stripes.
6. Reinstall the drum unit.
7. Close the front cover, pressing firmly on each side until the cover clicks into place.
Oct 12, 2009 | Brother MFC-8840D All-In-One Laser Printer
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Fax machine 2820
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner. You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times. 3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this: a Open the front cover b press the options key, the LCD will say "replace drum?" c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open. d close the cover, if the display still has toner life end, you will need to replace the toner
Oct 03, 2007 | Brother IntelliFax-2820 Laser Fax
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
