Fault code sc542 appears on screen - Office Equipment & Supplies
  • teviknj Apr 08, 2009
    I have a Ricoh Aficio 1035 printer that has the same code: SC542 on power up. Any help here would be helpful. Thanks.
The error code is related to the fuser area.
Likely to be a low fuser temp issue.
Need to verify good or bad heat lamps.
1) Check each lamp in fuser.
(lamp is good if you get continuity)
(lamp is bad if open)
2) Check the thermostat. (thermal control device)
(triggers if unit gets too hot)
3) Also check thermistor (monitors temp of fuser)
(2) total (middle and rear)
If heat lamp is good:
Your best bet is to change all three items. (Temp fix)
Fuser thermostat - thermal control device
Fuser thermistor (middle front) - thermal control device
Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time.
Fuser needs to be rebuilt or replaced.
(Check for wear and tear)
Inexpensive repair for the temp fix.
The whole Fuser cost can brake the bank.
I buy parts from precisionroller .com (you can preview the parts)
Franklin
baselinerepair .com
Posted on May 14, 2009
Why ricoh aficio mp 171 spf is showing servical sc 542?
because in some moment the fusing temperature was more high than the optimal. maybe it is just because of precaution issued the SC542. or maybe is problem . you need to reset the SC542 by entering the service mode. for this if you call service they will charge you big money. so if it is just issued just as precaution by doing the following procedure the machine will work fine again. but if the code do not clear do not repeat the procedure more than ones that you can make bigger damage that it has have before the code. so follow the next procedure: first enter service menu by pressing the following keys in order. press the yellow clear key the pres 107 and then press the red clear/stop key until on he screen write service menu or something other than the usual screen. after that appear. turn the machine of by the left side switch and wait 5 seconds, than turn it in again. if starts to work everything is okey . if the SC542 appear again do not repeat the procedure. call a serice techician
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Oct 22, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
What is the problem with code SC542 power off on
Mostly a fuser fault code. Repair fuser then rest code
Nov 04, 2014 | Ricoh Aficio SP C311N Color Laser Printer
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Now when i put my photocopy machine on the SC542 code error appears So i need a solution for this problem
Hi rfofie,
There's no specific brand or model you have mentioned on the issue that you needed help. However, I can provide you the meaning of the error code that you are getting. The SC542 error code is a Fuser Temperature Error. That means that the fuser did not warm up fast enough. You will have to replace the fuser to get rid off the error.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | Office Equipment & Supplies
I have a ricoh aficio sp c420dn, when and turn on the screen showing error sc542
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Jan 10, 2010 | Ricoh Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
This is the code that appears on the screen, SC542-00
This is a fuser code indicating that printer didn't warm in the correct time and could be caused by defective sensors, heating lamp, or low voltage conditions.
Will require a technician to the printer's service mode to reset and/or replacement/cleaning of defective part
Jul 09, 2008 | Ricoh Office Equipment & Supplies
SC542 code appears on my Rex Rotary 2822, give solution please
This means the fuser has an error. You can not reset the code even if the fault has passed without entering the service mode. If you need a service manual for this let me know and I will send you a link.
Apr 21, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
578 people viewed this question
jasbo
jasbo
