Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a reset switch but can't find it, even when I took the cover off the main canister unit. Where is the reset button and/or fuse?
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Posted on Aug 11, 2010
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
Can't detach vacumn hose from hose grip base to clean with canister.
turn it 90 degrees to release it , if you look you will see ( unless its reallly dusty ) 2 tabs that are inside the hose attachment itself
May 08, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
Power brush motor will not turn on. Tried everything. It's only 1.5 yrs old
hi. when the power brush will not turn, generally the belt is broken. Replace the broken belt and you should be fine. j.
Aug 02, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction on the bissell lift-off revolution
I had the same problem. In the water resevoir, there is a red flap that allows the dirty water to flow back into the water tank. Lift that flap up and there is a small red screen. Pop that screen out with a butter knife and rinse it out. I have dogs in my house and that screen was blocked by dog hair. I cleaned the screen, popped it back in and it works like a new machine. You would think Bissell would address this roblem on their web site but they don't.
Mar 09, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
729 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
