Question about Symbol MC9090 Barcode Scanner
The RF gun had been working. Now it does not connect. There is no signal icon at the bottom tight screen. Msg says connection timed out
    President:
  • 1,561 Answers
I advice you try to reset your device, resetting it will help fix the problem, you can check the user manual on how to go about this.
Take care.
Posted on Jul 15, 2010
  • Aley Raza Jul 15, 2010
    Can you please guide me how to reset
  • Sulaimon Jimoh Olayemi Jul 15, 2010
    I suggest you check the user manual as regards that, but you can follow this, power off the game and power on, while the game i loading, pull out the plug from the AC outlet and wait for a while before plugging it back and power on.
    Take care.
Acer aspire 1 display not showing when external monitor hooked up. Starts and then says no signal
You may have to activate the external display port. On some laptops they use on of the Fn key combinations (look for the blue icons on the F1-F12 keys) Find one that looks like a monitor screen. Press and hold the Fn button and then press the blue icon key and see what happens. If something undesirable occurs, press the same key combination a second time to return to previous state.
Mar 18, 2015 | Acer Computers & Internet
Why won't it connect to my computer?
As long as you have service and the jetpack is turned on it is transmitting a wifi signal. On the bottom right hand side of your computer screen is an internet icon--look where your time display is and this icon is just before the time. Click this internet icon and it should recognize the Jetpack signal. If it does, it will say "connections are available" right click on that and it will show available connections including the jetpack. Right click on the identified jetpack signal and then click on "connect" and enter the security key and now you should have full internet access. If, when you click on the internet icon, it does not say "connections available", then click on "troubleshoot" and let the device tell you what the issue is preventing connection.
Jun 17, 2014 | ZTE Verizon Jetpack 4g/3g Mobile Hotspot...
I have an L32HD31 TV and just recently the screen started to display these fine horizontal lines that cover 3/4 of the bottom half of the screen. Was wondering if there was a fix for this and what could be...
Check all your input cables. If RF coax, make sure they are just beyond hand tight. If RCA, twist each a few times to burnish (clean) connections. This is especially true if you are doing Component viodeo (Red, Green & Blue).
Nov 25, 2010 | RCA L32HD31 32 in. LCD HDTV
RF gun is not getting a valid IP address from a
Check to port assignment in the guns. Sounds like a encryption issue. Did you go through the connection procedure like you do with a PC? Port, passcode, etc?
Feb 09, 2018 | Symbol PDT6842-NIS632EU Portable Data...
Symbol 9090-G barcode guns loosing wifi signal.
I have seen this many many times.
Your problem lies with this statement:-
"I can even see every one of the AP's on the gun anywhere in the plant."
In simplest terms - you basically have too much RF signal. If you have 2 AP's on the same channel and they can see each this will cause problems.
You need to tweak your wireless network regarding power settings and channels. It’s a lengthy and laborious task. Start by getting a site plan, noting all the AP locations, channels and power outputs. Then look for ones that clash and amend. There are a few tricks and tips to use, but it’s basically keep adjusting until at any particular location the hand held can not see any AP's that clash. For a very large site it can take a few days to keep tweaking settings.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jan 12, 2010 | Symbol MC 9090 (sym-mc9090gk0hbega2r)...
I have a panasonic DLP rear projection t.v. There are bright colored spots on the screen. the screen has ghostimages and vertical lines.
Ghosting is usually caused by RF interference.
I would troubleshoot the video source rather than the projection TV.
The first thing to check with interference is the tightness of all connections. If your signal is transmitted via a coaxial cable, (which I'll assume because ghosting is common with coax) use a wrench to thread each connector tighter. Not too tight, of course, just a little more than what you could do with your fingers. Check the image.
If ghosting still apears, check the connectors themselves. At any point can you easily pull the cable out of a connector? Does the cable look like a good quality cable? If the cable itself is thinner than a standard pencil, the answer is no. A lot of manufacturers turn out crappy thin coax cables that cause many, many problems.
If you're pretty certain the interference is not attributed to bad wiring, consider the environment where you watch the TV. Are there devices within range that might cause RF interference? A CB radio? cordless phone? cordless microphone? microwave oven? wireless router? If so, these devices might be resonating with the video signal, causing the unwanted equivalent of a delay in an audio signal. Try unplugging these devices one at a time and observe what difference, if any, they make on your reception.
Report back if these tips are not fixing your problem.
--Matt
Nov 02, 2008 | Panasonic Televison & Video
Dual tivo recorder
Have you tried pressing the "TV Input" button on the Tivo remote to find the "RF in" signal?
Oct 29, 2008 | Tivo Series2 TCD649080 Video Recorder
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
Not connecting to satellite
open up your unit, careful when opening as the RF cable will be tight in between the boards. make sure there is nothing banging around in the unit.. (shake it and listen).. if yes then investigate and report back. if no, then make sure all the cables you can see are tight. especially concentrate on the RF cable.. long cable.. either black/carbon fiber or grey cable. One more place to check is your antenna, (which you'll have to take off before you open up your unit, so do this first) yea jut make sure the antenna is on the unit tightly. Also try resetting user data. + and repeat button at user menu, then select reset GPS data. -Daniel
Apr 18, 2007 | Magellan RoadMate 700 GPS Receiver
Maratz 5200 is dead
hi there.
not sure if this link will help you out,but have a look,scroll down the page and you might find what you are trying to find out.
Marantz RC5200 LCD Touchscreen Remote Control is dead Google Search
Nov 19, 2017 | Marantz RC5200 LCD Touchscreen Remote...
Symbol MC9090 Barcode Scanner Logo
702 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
