Question about D-Link Air DWL 700AP (DWL-700AP) 802.11b Wireless Access Point
How can I set up a password on my D-Link AirPlus G Wireless Model DWL-G700AP If I don't have set up disk
tech curly
  • 298 Answers
SOURCE: DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Posted on Aug 07, 2008
SOURCE: IP address
1. if you computer connected to the internet behind the router you can use this command under dos or command prompt.
ipconfig /all
under internet adapter local are connection look for gateway and thats your router IP address,
2. if you still cant access it .
force reset it to default settings
there's a small reset botton at the back of it, use pen to reset it and it will reset to its default IP address
try:
192.168.0.1<-- this is the default for dlink
192.168.1.1
192.168.1.0
Posted on Nov 18, 2008
acdr
  • 1913 Answers
SOURCE: How to make my wireless
acess your router http://192.168.0.1
or http://192.168.1.1
then user is admin
passowr dis bleank or admin
then selcet setup of nternet type is with static ip set ip and gateway.
also set security encryption key.
also enable advanced security.
then allow mec adreses of which u want to give internet.
Posted on Nov 29, 2008
rahul26485
  • 611 Answers
SOURCE: ihave problem iam make my D-Link AirPlus Xtreme G
if the router or modem has wire if wireless if there then they have the same seciurty option it means same passwork wep
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Posted on Dec 09, 2009
Connecting wireless router to server
If routing and remote access is enabled on the server, it should handle the bridging automatically between the two nics...
Otherwise, simply turn off the DHCP in the router, have the server and all the clients connect to the LAN ports, and they will automatically get their address from the server. In this scenario, you don't need to worry about the WAN port on the router.
But you might want to think about using the WAN port on the router to provide an added layer of security rather than exposing your server directly to the internet. You can set up all the port forwarding you need on the router.
More info here:
http://www.dlink.com/us/en/support/product/dwl-g700ap-high-speed-2-4ghz-802-11g-wireless-access-point
The manual is here:
http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DWL/DWL%20G700AP/Manual/DWL_G700AP_Manual_EN_US.pdf
You need a pdf reader (adobe) to read the content.
Good luck.
Nov 18, 2012 | D-Link DWL-G700AP 802.11g/b Wireless...
Hi i have a d-link dwl-g700ap and i cant acces the wifi from my garmin-asus a50 nuvifone , i know its not the phone because i can connect on everyother network . please help
Go to your management software inside the access point. Default IP address is 192.168.0.50. If you changed it, go to that address with a browser. Default login with "Admin" without a password. If you set up a different administrator id and password then login with those credentials.
Go to the "Advanced" tab. The setting on the MAC address settings are important here. Hopefully you know how to get the MAC address of the phone. I don' have the same phone so I can't tell you how to get it. Ensure that you have entered in the phone's MAC address and any other devices that you connect wirelessly to. If you have registered the MAC address under the second radio button or you have the first radio button clicked, you have a WEP or other password issue. Many public access point don't filter any MAC address and don't require passwords. When setting up at home, you do have to at least these up.
Hope this helps.
Aug 06, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
Can I use the dwl-g700ap as a repeater?
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
Connect D-Link DWL-G700AP to dreambox decoder
Router
Modem
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
Cannot set up DWL-G700AP
try 192.168.0.1
Usually that will be thr routers address.
some others commonly are 192.168.1.1
192.168.0.100
192.168.1.100
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Factory reset dwl g700ap
Bill,
I have here the steps on how to reset your device.
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Jun 05, 2008 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
Can not get the IP
Make sure that your security1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless1.gif zero client are started and set to startup type automatic.
Jan 15, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
D-Link Air DWL 700AP (DWL-700AP) 802.11b Wireless Access Point Logo
119 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
