Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
What do i need to do to replace a door hinge on a
What is involved in replace a door hinge on a hotpoint Aquarius wd63 washing machine
Thank you
Brendan Berry
  • 1,284 Answers
Hi, pull out soap draw, remove four screws holding top panel on, move panel to the right and unclip it from machine.undo three self tappers on the top of main front panel, they are now accessible. It is now possible to pull the top of the front panel forward enough to reach down and grasp the inner hinge retainer and once both screws are removed lift it out. You were perfectly correct about the door, it came apart with a little gentle persuasion with a wide bladed butter knife. Job now done.
Take care
Posted on Jul 15, 2010
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Could you please tell me where i can find the filters on the hotpoint aquarius extra WD63? Thank you
Remove rear panel completely from washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WD63 Front Load...
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd63
take door off. outer porthole is just clipped into frame. gently prize out with a small screwdriver
Mar 04, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
