Question about Dell Laser 1720 Printer
How can i rest photoconduct kit is finished life time?
  • 241 Answers
To resert drum counter, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Posted on Jul 15, 2010
My ricoh aficio shows sc990 how can i fix this problem?
first you check pm life of drum kit if finished than replace it
second clean laser unit (ld) you will discover that this code will never shows again.
Aug 12, 2012 | Ricoh Aficio 1035 Copier
I have a 3.5HP 11 gallon compressor. Recently it made strange sounds while in use with my finish nail gun. I unplugged it and finished the job with the pressure left in the tank. After a day of rest, I...
Oil-less compessors have sealed bearings within the motor and at the piston rod journal. These bearings do wear and dry out causing noise. Replace the rod bearing as needed (the motor bearings too difficult, expecially front). The piston has a vinyl/teflon ring and wears over time (piston/cylinder kit not expensive) . The condition of the cylinder can be determined by the length of time the unit takes to fill and shut off. One should note the time to fill when new, then compare as unit wears (from a few minutes to up to ten when worn). Good luck
Jul 02, 2011 | Campbell Hausfeld Air Tools & Compressors
Magenta toner smearing and there is also a line down the middle of the page
This is most likely due to a problem - like a crack - with the scraper on the drum cartridge that keeps the photoconducter clean. You should probably have that replaced, and replace the drum as well. FWIT, you should never touch the photoconductive surface of the drum - you can damage it, or leave fingerprints on it that will affect the print quality.
Oct 06, 2010 | Dell 5100cn Laser Printer
84 Replace Photoconducter
Here's the link to the Lexmark website for instructions on how to install the photoconductor and resetting its page count on a Lexmark X340n. http://bit.ly/c66dvv. If 84 Replace Photoconducter message is still on the display after performing the steps, refer to this link on how to reset the photoconductor page count. http://bit.ly/bm3XBm. If all else fails, I suggest you contact Lexmark Technical Support for further assistance.
May 21, 2010 | Lexmark X340n All-In-One Laser Printer
995 engine error everytime we try and print
it is in reference to the photoconducter cartridge.
1. shut off power to printer. Pull your photoconducter unit out and check the position of the black marker located on the edge of the tranferbelt. I know one time I was fortunate enough to fix this error by rotating the photoconducter belt so that the marker was in a different position. Becareful not to touch the photoconducter belt (green shiny part) if at all posible. Reinstall the unit and power up.
2. If the above trick doesn't fix it after turning the printer off for a few minutes and you still get the same error when printing... You will have to replace the photoconducter unit.
tell me incase any issues
May 05, 2010 | Lexmark C510n Laser Printer
Driver blade won't retract to shoot the next nail
Sounds like you have something caught in the guide causing it to jam a lil.
These guns are allmost disposable and have a short life span.
Mar 31, 2010 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
Lexmark C510 995 Service Engine Error: I can turn All four toner cartridge gears, but they all seem to turn quite hard by hand. Is that my problem?
2. If the above trick doesn't fix it after turning the printer off for a few minutes and you still get the same error when printing... You will have to replace the photoconducter unit. I wasn't as fortunate the second time I attempted the above trick and ended up having to order a new one. But hey its worth a try!!
Jan 30, 2010 | Lexmark C510 Laser Printer
Battery wont hold charge
its finished its life cycle, time to buy new one
Jul 30, 2009 | Milwaukee Tool V18 Hammer Drill Kit
Disconnected printer
If the lights are solid -
The error is caused by a defective cartridge, an unsupported cartridge, an invalid refill, or a cartridge meant to be used in another geographic region.
• If the print cartridge is not installed, install it.
• If the print cartridge is installed, remove it and install a new print cartridge.
If the lights are flashing
This means the photoconducter kit needs replacing
Sep 07, 2008 | Lexmark E240 Laser Printer
Error code Lexmark Optra 1275 Printer - 84 PC Missing
Usually there is more to this message particulary if this is a color printer. Basically the printer is telling you that tyhere is a problem in the Photoconducter area of the print cartridge. Normally I would expect to see a 84 PC end of life. Can you tell me if you left some information out, please?
Sep 03, 2008 | Lexmark Optra SC 1275 Laser Printer
Dell Laser 1720 Printer Logo
127 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
