Question about Maytag Neptune FAV6800AW Top Load Washer
Rust inside washer around tub rim and also around bleach dispenser.
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Jul 15, 2010
    Everyone who owns the machine has the same issue. Are there issues affecting machine operation?
ttech
  • 139 Answers
SOURCE: Rust inside my washer
Use Oxylic Acid Crystals dissolved in hot water and test for color fast if applicable, carpets, clothes, washer, toilet, surfaces, etc. Oxcylic acid is a white crystaline acid which reacts specifically with Ferric Oxide, (rust) and oxidises the stain quite selectively. Few teasthingys in a small bowl of hot water and a toothbrush. Purchase cheap at local hardwares Hope this Helps Let me Know Ttech
Posted on Jul 24, 2007
SOURCE: NEPTUNE WASHER
My washer had the same problem, first not dispensing bleach or softner and then it began stopping altogether several times during the wash cycle. One we removed the water hoses and thoroughly cleaned them out, the problem was solved-apparently not enough water was flowing and the washer couldn't cycle properly. Good luck.
Posted on Feb 18, 2008
SOURCE: Whirlpool Washer LSQ9645KQ0
The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
di_marie60
Posted on Aug 12, 2008
SOURCE: Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Posted on Aug 25, 2008
JR JR
  • 116 Answers
SOURCE: Bleach dispenser
RU SURE ITS NOT WATER NOT BLEACH ,,THERE WILL ALWAYS HAVE WATER IN THAT DISPENSER
Posted on Nov 30, 2008
The lid to my whirlpool cabrio top loading washing machine will not open completely???
Hello. How old is your washer? Is there rust around the bleach dispenser near the left side hinge? What probably has happened is the hinge assembly underneath the top cover has rusted from the contact with chlorine and or fumes. These washers are notorious for rusting at the hinges, especially near the bleach dispenser. The parts involved are:
left hinge arm--w10389421
right hinge arm--w10389240
left hinge spring assembly--w10358931
right hinge spring assembly--w10358932
top cover--w10391067--if this needs to be replaced, call for service--it's a solid hour to 90 minute job for an experienced tech! You have to transfer ALL THE PARTS to the new cover and it's INVOLVED--trust me! If there is rust around the bleach dispenser and underneath the top cover, you might check your serial number with Whirlpool to see if you can get a new top cover for free covered by a service bulletin dealing with rusting. To raise the top cover, remove the top screws from the hinges on the rear of the washer holding down the top cover. Then, remove the screw and metal plate protecting the wire harness and pressure hose and set it aside. Next, from the front, slide the top cover forward 1/2 inch and lift up. Have a friend assist you in holding up the top cover. You can now access the hinges mounted underneath, check for rust, and also see how the suspension rods are mounted(they are very easy to remove since there is a slot in each rod holder located at each corner at the side of the tub near the bottom. You would pull up on the tub, release the top of the rods first, then reach down and unsnap the plastic clips(2) in the center of each holder. Use a headlamp or flashlight to see. The rod will drop down and can be removed through the slot. Reverse the procedure to install.
Also, in case your suspension rods get worn out(the tub has a hobby horse "bouncy" movement), the part number for the set of 4 is w10368625. The proper way to check the rods is to place your hands on the right and left side of the tub ring(the plastic cover over the basket) and shove smartly down and release--the tub should grip going down and pull coming up--no springy movement--just like shock absorbers on a car. It should come up and settle. If it has any bounce at all, the rods are worn--symptoms will be increased out of balance errors or the washer might start banging during spin. I hope this helps you. If you are hesitant about performing any of the repairs above, please call for service!
Oct 03, 2015 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
What do I do to stop the rusting?
Stop using bleach in the dispenser. Just put it in the tub after your wash machine has filled with water. The problem is, bleach eats away at the enamel and metal and if you don't have it sufficiently diluted with water, then it eats away at everything---really fast!
Oct 24, 2014 | Whirlpool Washing Machines
Whirlpool duet dispenser to tub hose keeps cracking/ripping. why?
carefully check the position of the clamp, as the tub moves around during the wash and spin cycles the ears of the clamp been rubbing through the hoses
May 12, 2014 | Whirlpool 8540063 Washer Hose, Dispenser...
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
The bleach dispenser did not dispense bleach during Tub Clean cycle. The drawers were clean (only have had washer 3 wks)
I just called LG and they said for this model WM2101HW the bleach will only dispense from the soap dispenser during the tub clean cycle
Apr 16, 2010 | LG WM2101HW 4.0 cu.ft. Washer
How do i clean the Whirlpool Gold american collection top loading washing machine? I can see no filter to remove and the inside of the tub is getting dirty. The holes inside the tub at the top seem to be...
Dumped even more HOT HOT HOT water while poking around inside dispenser. Softener dispenser suddenly became unclogged and water began running out of the opening showing me that the dispenser was indeed clogged with softener buildup.
Sep 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
di_marie60
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Jul 24, 2007 | Kenmore 22422 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
196 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
