Question about Amcor PLM-14000E Portable Air Conditioner
Amcor 10,000BTU set at 64 degrees - - temperature of air coming out of unit is 72 degrees. In one and half hour set at 64 degrees the room temp only went from 90 degrees to 84 degrees. Recommendations? Recharge?
    Problem Solver:
  • 6 Answers
I am not sure, i have a similiar unit that is brand new, seems like a faulty mechanism from the maker, it starts cold for about 2-3 minutes and then shuts down condenser and blows hot air repeating this cycle. I don't believe it ias a recharge, just a faulty machine
Posted on Jul 20, 2010
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
It is 94 degrees out side and inside air 78 i got the troastat set on 72 what does it meen that it want get 72 in the house
depending on the current conditions inside it appears to be wotking fine with the heat load. what I am saying is -is that the air coming out of the unit shuld be about 15-20 degree lower than the temp of the room .. close all unused room s and it will do its job.. Hope this helps let me know Jon
Jul 27, 2011 | Haier Energy Star ESA3183 Air Conditioner
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
I just installed a honeywell 5-2 progammable thermostate.. Everything is hooked up fine and I have my days, hours wake, sleep, leave...etc all set, but when it goes on.. for example, I have it set for...
You didn't include a model number, so it's hard to know for sure - but I'll take a stab at this one. Many of these t-stats have a programmable offset to reduce "hunting". This can be as little as 1 degree or more than 2 degrees.
This means if you set the offset to 1 degree and the room temperature to about 65 degrees, the furnace will heat the room until the t-stat registers a rising temperature of 66 degrees. The furnace shuts off and will not turn on again until the t-stat registers a falling temperature of 64 degrees. The average is 65 degrees, and prevents the furnace from starting and stopping numerous times instead of just once with the 1 degree offset.
You can further reduce the number of furnace start and stops by increasing the offset to 2 degrees. This would work like this when the t-stat is set to 65 degrees and the room is cool:
Room Temp Furnace
63 On
64 On
65 On
66 On
67 On
68 Off
The room is now warm and heat or furnace is off. The room begins to cool like below:
67 Off
66 Off
65 Off
64 Off
63 Off
62 On
With a 1 degree offset, the room temperature varies +/-1 degree (about 2 degrees total). With a 2 degree offset, the temperature about varies +/ -2 degrees (about 4 degrees total).
Also, when the thermostat shut the heat off, the heat that was made is delivered to the space instead of wasted by sending outdoors - so the room will get a little warmer even though no fuel is being burned. The same holds true at the other end. When the t-stat turn heat on, fuel is burned, but there's little heat until the source has reached the optimum temperature and then the heat is delivered to the space.
I hope this helps & good luck! Pleas rate my reply - thanks!
Jan 24, 2011 | Honeywell Programmable Thermostat Heater
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
Have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Jan 13, 2010 | Rinnai Heating & Cooling
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Mar 19, 2009 | Kenmore 72059 Air Conditioner
Heater!!!
I am experiencing a similar problem with my Mitsubishi slimline MSH09TW unit; about 4 years old; It use to give us very hot air now it is giving some what hot air; northeastern USA current temperature about 15F. You think frigid weather in Cranbury NJ could be responsible or some thing else is going on. Please help me if you have some time and knowledge about Mitsubishi heat pumps. Sincerely, DSS
Oct 31, 2006 | Mitsubishi MS12TN Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
315 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
