Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Can't use my remote with my Panasonic tv
I believe I need to reprogram my remote to my tv as when I moved the remote stopped working. It is an older tv but is going strong. Thank you in advance for the advice. Frustrated in Hagerstown
    President:
  • 1,099 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote.
Thats it, I hope you got it going again?
Posted on Jul 15, 2010
  • beatriceclar Jul 15, 2010
    Dear toolkits-I have a brand new remote and neither my old or new remote work now. I think it needs to be reprogrammed but I don't have the information now to do so. I think there may be something mechanically wrong with the tv not the remote. Frustrated in Hagerstown
  • Sanyade Akinwale
    Sanyade Akinwale Jul 15, 2010
    hello,
    You must access the menu fuction.Autosearch or manual add or erase channel
    1. Step 1
    2. Access the on-screen menu by pressing the Menu button located on the upper left side of your remote.
    3. Step 2Find directional arrows, or cursor buttons, in the center of the remote. Use the up and down cursor buttons to scroll through the menu until you have highlighted "Install."
    4. Step 3Use the right cursor button to display the features of the Install menu. Use the up and down cursor to scroll the features until "Auto Program" is highlighted.
    5. Step 4Press the right cursor button to start scanning the channels. This feature stores a list of all available channels in the TV's memory. When it is finished, it tunes to the lowest available channel. From now on, when you press the + and - channel buttons located under the cursor buttons, you should only access the local or cable channels.
    6. Step 5Press the Status/Exit button, located on the upper right side of your remote control, to remove the menu from the screen.
    Good luck, hope this helpout.......
My panasonic up/down channel buttons on the side of the tv wont work
Try getting a Harmony remote control. It will operate your tv and anything else you can connect to it. When the TV gets too old to fix, the remote can be reprogrammed for the new TV, so it never gets obsolete. The remote is programmed from their website.
Mar 20, 2014 | Panasonic Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Sep 30, 2009 | Panasonic DMRES15 DVD Recorder
Reprogrammig remote
Contact remotefinder.rca.com/default.aspx?site=rca for your proper programing code for your remote.
Oct 24, 2008 | RCA Universal Remote Control
Bright Star Br100P-D remote TV Panasonic
the remote is a hotel remote. Bright Star BR100P-D For a thomson tv. I just need to know how to reprogram the remote.
Jul 14, 2008 | Televison & Video
No response from remote
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Jan 27, 2008 | Panasonic CT-32SL14 32" TV
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
