I also have a problem with the fax image on the receiving side when I send the fax the image come out streaked as though its too fast in the scan. Is this a scanning problem when i fax how can i adjust this on a Dell MFP 3115cn
  • yan dikshteyn Jul 15, 2010
    thanks this worked
  • 493 Answers
You can set it up from the menu. You need to adjust the document resolution for scanning.
Adjusting the Document Resolution:
Use the Document Resolution setting to improve the output quality of the original or if scanning photographic materials.
  1. Press "down arrow" until >FAX appears, and then press "ok" .
  2. Press "down arrow" until >Resolution appears.
  3. Press "right arrow" to select the desired setting, and then press "ok". You can select super fine for high quality faxes.
NOTE: Faxes scanned in the Super Fine resolution transmits at the highest resolution supported by the receiving device.
You can download the User Guide from this link which I uploaded for you.
If tihs doesn't help you may have uncompatible driver and you can update your printer/scanner driver compatible to your operating system.
Hope this helps.
Posted on Jul 15, 2010
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
When I fax out the receiver gets a black streak down the side of the page I faxed????
clean the glass underneath the control panel. could have white out or something on it. however, if its a bunch of streaks, it could be your CIS, or contact image sensor, is bad. will need to be replaced by a tech.
hth,
razors
Jul 13, 2010 | Brother IntelliFAX 4100 Laser Fax
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Panasonic UF-490 - Two streaks down page
Either the glass is scratched or the sensor has gone bad that is used to scan the image.  Are you using a document feeder or laying it flat on the glass?  If you are laying it flat on the glass then it is most likely a sensor going bad.  If you are feeding it through the document feeder it could be that the feeder itself needs to be cleaned, or the paper path through the feeder.
If it is the sensor you will need to send it out for repair.  There may be an option to re-calibrate the scanner in the software, that may help if the sensor has just degraded and not failed.
I hope that helps.
May 02, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Streak
Open the document feeder and clean the scanner glass.
Nov 08, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Fax machine in sending
That would be comming from the scanner. The scan glass is either dirty or the scanner ccd defective. You can clean it well with glass cleaner or alcohol. Try unplugging the fax for abour 10 minutes and try again. And oddly enough I have seen poor connections on the print cartridge cause that. Just remove the cartridge and re install it.
The more likely issue is in the scanner, Either dirt or some bad segments.
Mar 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
19 people viewed this question
k24674
Marvin
Marvin
