Question about D-Link DCS-5300 Network Camera
What does each button stand for - D-Link DCS-5300 Network Camera
  • 524 Answers
Hi...
i suppose you are asking about the remote control buttons...
Arrows:Use the Up, Down, Left and Right arrows to tilt/
navigate the camera lens.
Home: Returns the camera lens to the home position set
by the user.
Auto-Patrol: Enables the Auto-Patrol function.
Auto-Pan: Pans the camera one full cycle.
Center :Centers the camera lens.
Stop : Stops the movement of the camera during pan.
Posted on Jul 17, 2010
What does the F/T button stand for?
What type and model phone!!
Sep 17, 2014 | Cell Phones
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
2002 yamaha v star 650 wiring diagram
The starter button is supplied with voltage from the engine stop switch internally in the right hand handlebar switch. Dissassemble the switch and verify that you have voltage to and from the stop switch. You will see the jumper wire to the starter button circuit board verify that it is hot when key and stop switches are on then verify if voltage passes through when button pushed. If not dirty or melted contacts in the button switch could be the cause. If voltage passes it goes to the solenoid next Via a side stand relay. This relay obtains a ground from the side stand switch. You can jump across the side stand switch to test it. From there the side stand relay must be checked or replaced. Keep following the voltage path untill you find where it stops and repair or replace as necessary. Good luck!
Dec 30, 2012 | Yamaha Motorcycles
I am looking for the remote code to pair my toshiba 40xf355d tv to my sky hd remote. Can you help?
0156 works for me 3/1/2015
Turn on your Toshiba TV.
Press the TV button on your Sky remote control.
Hold the Select and RED buttons for several seconds until the LED blinks twice then release.
Press the TV button again
Enter the 4 digit brand code: 0156 - the LED will blink twice
Point the remote at the TV and press the Stand by button.
If the television goes into Stand By press the SELECT button to store this code.
If the TV does not go in to Stand by mode, press the TV button and repeat from step 6
Dec 14, 2010 | Toshiba Televison & Video
In moving to a new apartment I flattened the neck of the circular stand with the monitor LG flatiron slim 19" into the box. Went very easily. Now when I put up my computer the stand of the monitor...
On my HP monitor on the stand, I have a locking mechanism that doesn't allow the display to be raised. I need to press a button on the stand while pushing down the display, then the button is possible to be pressed down. then while holding it down, I can pull the display upwards as much as it comes.
the stand locks in my case when pushed all the way in.
Maybe this is the same thing on yours? Maybe not?
Oct 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
How I can enable Hibernate and Stand By button? I have windows XP SP3
Here is a tip to know how to use and enable Hibernate and Stand By button.
In the keyboard to find the button for Hibernate and Stand By button.
Sep 14, 2009 | Computers & Internet
When I push the stand-by/on button - stand-by blinking
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Sep 10, 2009 | Onkyo TX-SV373 Receiver
I have plugged my Alto Coredless but it is not work. The like in the stand is not on.
  1. Make sure you have plugged in the stand’s USB plug into your note book first, and turned on your computer.
  2. Next, on the right side of the stand, there is a connection button.
  3. Press it. You will see lights (A and 3) Flashing back and forth.
  4. While the lights are flashing back a forth, look under the keyboard inside the battery compartment.
  5. Place in battery slot, 2 (AAA) batteries.
  6. Next to the battery slot is a little red button, press it.
  7. The lights on the stand should go out.
  8. Your keyboard is connected to your laptop.
Jul 07, 2009 | Logitech Alto Cordless Laptop...
My Logitech Alto Cordless Laptop Stand Keyboard stopped working. the stand still works but not the keyboard. I changed the batteries for new ones and unpluged it, restarted the laptop. But it stil not...
Have you tried the connect button underneath the keyboard? Sometimes they get out of sync.
You will have to press the sync button on the stand first and then press the sync button on the keyboard. Good Luck
Mar 20, 2009 | Logitech Alto Cordless Laptop...
D-Link DCS-5300 Network Camera Logo
202 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
