Question about Sharp AL-1000 Laser Printer
What does the red trinagular warning light mean? How can I clear it?
    President:
  • 1,561 Answers
If this triangle is a stack of 6 dots then this is indicating that your toner cartridge is empty and needs to be replaced or refilled. If you turn the machine off then on again it should run for several minutes while making a light thump, thump noise. This means it is trying to add toner.
Replace your cartridge or have it refilled and you should be good to go.
Take care.
Posted on Jul 15, 2010
The spot for brakes on the dashboard has an IP lite up on it. what does that mean?
CHECK OR HAVE SOMEONE CHECK BRAKE FLUID LEVEL, BE SURE PARKING BRAKE IS NOT ON!
Jan 22, 2016 | Cars & Trucks
When you power off the unit, it goes from bright led to low light led and shows a red light staying illuminated. Which means its STILL drawing battery. How do you turn it off completely?
Brake Hydraulic System Red Warning Light - RepairPal
repairpal.com/brake-hydraulic-system-red-warning-light
If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Sep 10, 2015 | Cars & Trucks
What does a red warning light with exclamation mean?
check your owner manual, but I can tell you any red warning light on that means it is dangerous unsafe to drive, you got to becareful with those lights on light oil light, brake light, air bag light, so on.
the yellow light is ok to drive but you need to check it on sooner or later to prevent further damage to the car.
hope this can help you.
Aug 17, 2014 | 2000 Toyota Camry
2000 regal security light on
The ECU had reports that repeated which in turn would bring on the warning light. When you turned the ignition off then on again if the fault was no longer being reported it would put the warning light out. The fault memory will still have that record. Best get the fault memory interrogated (special fault reader required) to find out what action if any is required and also clear the memory.
Nov 10, 2017 | Buick Cars & Trucks
The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Apr 10, 2010 | Freezers
Red warning light shows up
It is because of weather when the weather is not clear or it gets rain the device is unable to catch the signal that's why it get red. :)
*Cheers*
Dec 15, 2009 | Alvarion Wireless Access Point
I just put a new case on my 360 and it has a clear pece that goes over the dvd drive so you can see the disc when i play for at leat 30 minuites the video cuts out the controoller continues vibrateing and...
left side, means thats your 2 red lights is your AV/HDMI cable not connected properly. 3 red lights is the ring of death. 4 red lights is the disk drive/laser has gone.
Aug 09, 2009 | Microsoft Xbox 360 Console
My abs light is always on and now my brake warning light is on but brakes seem to be working fine
The ABS light is a warning that you have an issue with the ABS system. The red brake warning lamp is serious. It is telling you that there is an issue with the base brakes. Your car will be ok with an ABS light, but the red warning lamp could be really dangerous. You should have them checked ASAP. It could be from many causes. A park brake switch, low fluid, the causes are too numerous to list. Please for your safty have it checked. Good Luck
May 29, 2009 | 1997 Chevrolet Malibu
Red box shaped warning light-2002 saturn sl2
If the symbol looks like this:
10fb1f7.gif It means your coolant is low.
Jan 15, 2009 | 2002 Saturn Sl
Sharp AL-1000 Laser Printer Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
