SOURCE: Like to know whether my Samsung 997DF 19"Monitor still carries the warranty
Go to the manufacturer's website, see if the warranty period is posted there.
You might post the problem here- some problems can be simple to repair, and, as usual, others are not even close to simple.
SOURCE: D52GW12 bulb
I MIGHT HAVE A USED ONE THAT WOULD WORK,,IS THAT LEGAL STATING THAT?? ,,,ALSO CHECK AND SEE IF THERE IS A FLUID SPILL ON THE BOTTOM OF THE TV AND MAYBE ON CIRCUIT BOARDS--YOU MAY HAVE MORE PROBLEMS THAN U THINK--TUNICA
SOURCE: Looking for a part number
Pump part # is 8540024 cost is $59.99 at SEARS.COM. Hope that helps,
XCEL Energy Repairman
SOURCE: using powder 1/2 recommend amount. there is a
Hi
When you start a cycle, does the machine take a long time for it to fill up with water.
If so, you have a faulty inlet valve. There is a rubber diaphram inside the valve which tends to tear over time.When this happens the water just trickles in. Therefore the soap/powder is not dissolved into the tub thouroughly.
Some powders also dissolve less than others, and using the machine on hot water cycle helps to dissolve the soap faster.
Regards
Ash
In order to remove plaque from your teeth you should floss daily between your teeth and in the areas that toothbrush cannot reach. Moreover, you should brush your teeth properly twice a day.
