Question about Whirlpool Refrigerators
I have a whirlpool fridge modelET8WTKXKB10 , SER. #EW3917697 and i have had to buy about 40 motors FSP-12002744 EVAP. MOTOR , I have 160 fridges and have been using them since dec of 09
  • tweinand Jul 15, 2010
    SORRY IT SHOULD OF SAID DEC. OF 08 , I JUST WANT TO KNOW IF OTHER PEOPLE ARE HAVING THE SAME PROBLEM? tHERE IS NO RECALL.
    President:
  • 1,218 Answers
Good day,
Don't know what your question is ????
However, if the machines were new as of 12/9 then they would be under factory warranty since the're under 1 year old. You should have been able to have them replaced free of charge.
If your concerned about having to buy motors for the rest of them, I would contact the selling dealer regarding possible recall bulletins.
Posted on Jul 15, 2010
  • John Hall Jul 16, 2010
    Good day,
    Yes many have failed early. Way too early. The appliances being produced today leave a lot to be desired. The're trying to replace dependability with effeciency, and the consumer is paying heavily. Not just you. What I see posted here is very disheartening. It's an accross the board fiasco.
    However, you might want to look here. It's a modified motor. But for the balance of your fleet I have no answer other than writing nasty letters. I wish you luck.
    http://www.appliancepartssolutions.com/1...
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
How do i know if my fridge is worth fixing?
you probably just lost the evaporator motor in the freezer. easy to replace and it's only around $50. look up the model number and you should be able to get the part number.
May 13, 2012 | Whirlpool Refrigerators
Squeaking fan
Try unplugging the fridge, spraying the fan motor with WD-40 -- everywhere you can reach -- then plugging it back in.
Jan 07, 2012 | Hotpoint HSS25GFP Side by Side...
Fridge Motor
which one?evap fan motor or the condenser fan motor?i've seen the evap fan blades in the freezer wear out in the center where it slides onto the motor shaft so when the motor comes on the blade doesn't spin with it,need a new blade,or if the freezer is on top the drain blocks and the air vents freeze up,is there water leaking anywhere or ice on the freezer floor?need to send a little more info,also model number would help
Jan 23, 2010 | GE Refrigerators
Kitchenaid Bottom mount refridgerator is has stopped cooling but freezer is maintaining correct temperature
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/36832aba1a29de4d852570ad004ec13e/$FILE/FDBMREFRIG.pdf
We replaced the evaporator motor. Use an Ohmmeter to see if electricity is going there, first, see if fan is running, then, if not, replace evaporator motor-part # 12002744.
Fridge is now running! I'll post again, if there is any more to the story. We are now waiting to see if it gets to temp, but it is running. I'd love to find info on a reset code.
Sep 23, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
The fridge is 4 the freezer is 4 the problem is fridge warm
Can you hear a fan motor blowing or feel air blowing in the freezer section? I'm thinking this fan has quit running and is not distributing air to the refrig section. If this fan is running then check that you can feel air blowing out of the vent at the top of the refig section if not check that the damper is open. you can do this by removing the grill on the vent (it just snaps out) as warm as the refrig is this should be wide open.
The fan os the most likely and most commonly seen problem for me. the part number is 12002744 and is approx 40 dollars. this is a fairly easy fix if your mechanicly inclined. if you call a service company you will be looking at 150-250 depending on the company.
If you have any further questions leave me a comment here thanks Peyton
Mar 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
