Question about Pelco Video Recorder
I have 6 pelco make 5104 dvr connected to a
I have 6 pelco make 5104 dvr connected to a TCP/IP LAN. For remote client monitoring I have to close one VPN session and start another. I want to remain connected to all the 6 dvrs continiously. how can I do it?
    Problem Solver:
  • 5 Answers
I've had numerous problems with my Pelco equipment over the years, they launched some new online help community where a tech rep will provide you with solutions and links to software relatively quickly.. http://buildingscommunityhome.schneider-electric.com/Signin.aspx Calling customer service hasn't worked out so well for me in the past, so far their online support seems to have their act together
Posted on Oct 25, 2012
We developed a unit called ThruLink specifically for Pelco Endura over a WAN. It simplifies the process of creating a VPN, and allows you to connect as many remote locations over any WAN connection into a single unified network.
You can view the product details on the pelco link below.
Pelco Endura over a WAN Simplified
Posted on Sep 29, 2011
  • 3 Answers
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Posted on Jul 15, 2010
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
There is an error in connect...........
If the error in connecting to the internet or to a LAN is prevalent with all network adapters, reset the TCP/IP Protocol stack byrunning the following command from the command prompt window:
1. Go to start menu and click on run.
2.Type in cmd.exe and press enter.
3.In the command prompt window,type in the command:
netsh int ip reset C:\connlogreset.log
The command will reset the TCP/IP protocol stack to it's defaults, and the reset data will be logged in the text document connlogreset.log.
If the above fails, disable any protocols that are not needed in the connection, e.g. SLIP(Serial Line Internet Protocol for Linux) as it's only used to connect to Linux servers in a LAN.
If using a broadband modem, disable NDIS driver wrapper from the GSM broadband client software provided with the modem, and update the software if possible.
Jan 01, 2011 | Computers & Internet
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
No IP Address
please check under network connections if there is a "Network Bridge", if there is then simple delete it. If there is none, go to local area network>properties>uncheck TCP/IP then hit OK or close. Restart machine. After restart, go to local area network>properties>check TCP/IP then hit OK or close. Restart machine. This should fix the problem.
Jun 25, 2009 | HP Computers & Internet
Status of wireless is connected but cannot browse
Check with this tip
Let me know if everything is clear and if you can put every setting matching on both sides: Access Point (= router, AP) and Client (PC).
Radio connection IS different from browsing Net.
Can PC browse internet when connected with LAN cable to same router?
Are both on same subnet?
Have you checked if an access list is installed in router firewall?
Is the Client blocked /allowed in Firewall?
Can you ping router from Client?
Did you see the router as default gateway in Client IPCONFIG?
Is Router IP address in HOST client file?
Any antivirus, firewall (like Zonealarm) software blocking some new LAN connection and requiring to unblock?
Jan 25, 2009 | WiFlyer - Portable, shareable WiFi base...
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
I'm looking to hookup the DVR with the PC via A cross-over cable
I have 2 DX2000's, In order for you to communicate with your pc, you need a Crossover cable, if you have a laptop or computers, connect the crossover cable to that, set your ip address on your computer to 192.168.2.108, (Note: since you never configured it, this would be the default setting). If you have the manual this is in there.,
Another method, if you don't have a crossover cable is to set the ip on your computer to 192.168.2.110 Subnet, 255.255.255.0. its a little more funky, the crossover would be easier, once you get in, then go to the configuration page and setup up the IPaddess for the DX2000, the Gateway to your Router and the subnet mask, once you do this, then you're able to get to it on your network, by typing in http://xxx.xxx.xxx.xxx:8004 .
Actiontec GT701-WG doesn't recognize a DVR on the LAN
I think the screen you may be looking at is the Application layer forwarding screen, the drop down box being populated by DHCP clients, that's why it isn't seeing the DVR. The DMZ Hosting screen doesn't have a drop down box, it only requires an IP address to be entered.
Hope this helps!
-Backu
Jan 16, 2008 | Actiontec (GT704WG) Router
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Pelco   Video Recorder Logo
204 people viewed this question
Top Pelco Televison & Video Experts
Electro Med Services...
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
