Question about Nikon Coolpix L11 Digital Camera
Lens error in my camera. how to rectify - Nikon Coolpix L11 Digital Camera
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 15, 2010
How can I rectify the "zoom error" message on screen - also the lens will not retract either
Hello
Unfortunately a "zoom error" message is not something that you will be able to fix. This error indicates a system failure (apparently your lens is damaged, since it will not retract) and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 12, 2010 | Fuji FinePix J10 Digital Camera
NIKON COOLPIX
The Camera displays lens error only when it's unable to retract or expand. This usually happens when the internal Hardware that controls the lens fails or any dust particle settles around the lens. In this case, just give slight bumps to the Camera against your palm. If the issue persists then service will be required.
Dec 01, 2009 | Nikon Coolpix 5700 Digital Camera
Lens error when turn on camera
not sure if you take a camera from an air conditioned room or house to a humid outdoors condition that may cause this problem. Check manual for other trouble shooting if you don't have manual go to this site and get manual http://tv.manualsonline.com/search.html?q=vr+5940&submit.x=35&submit.y=14
Aug 28, 2009 | Cameras
Error message on display
you might have a stuck shutter. have it checked by nikon..
Jan 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens is jammed for Canon Powershot SD200
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2009 | Canon PowerShot A470 Digital Camera
My Canon Ixus 9501S which is normally fantastic just developed a "Lens Error - Restart camera". The lens will not retract and I have no way of rectifying the problem as yet. Camera is about 12...
Hi
There is no camera reset for this model, what you are seeing is a generic stuck lens error message. If your camera is less than a year old, try and get it repaired under warranty first.
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam') $75 is all it takes to install a new lens for you; just let us know if we can help!
Good luck from
Darntoothysam com
Sep 25, 2008 | Cameras
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Jan 21, 2007 | Olympus MJU 400 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
172 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
