Question about Refrigerators
My kenmore 2535718860 consistently leaks water from the bottom of the refrigerator,upon awakening I have to clean up puddles of water daily. I suspect that it might be the drip pan,if it has one. Can you assist?, will like to address this issue without calling repair people.
  • 677 Answers
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
CAUTION!! Always unplug refrigerator before attempting ANY kind of service and/or moving it!!
  • Use caution with anti-bacterial products. Make sure that any such products cannot flow back into the food compartment.
Things You'll Need
  • Wire hanger
  • Anti-microbial agent such as chlorine bleach, rubbing alcohol or anti-bacterial soap.
Posted on Jul 15, 2010
  • 1 more comment
  • pete1371 Jul 15, 2010
    Is there a diagram that I can use to identify drain hose or the specific area I will be working on?.Additionally what parts have to be removed in order to get to the hose?. Specs will be most helpful.
    Thanks,
    Peter
  • ikechukwu joshua
    ikechukwu joshua Jul 15, 2010
    Use this link as a guide (archangelappliancerepair.blogspot.com/2009/06/what-do-you-do-when-you-find-that-your.html).
    Take care.
    not helpful. need to see diagram of refrigerator in order to see exactly what it is that I have to do..
    Your response is ambiguos and does not help resolve problem of where it is that I need to work from.
    peter
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
Leaking water
can you be more specif on when its leaking water? where? how often? is there ice on the bottom of your freezer? does it only happen when you ask for water from your dispenser? does it come in a puddle every three days or so?
Aug 05, 2013 | Kenmore Refrigerators
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer leaks since we moved it to fit vinyl flooring in kitchen
Generally there is a water tray at the very bottom that can be slide out and in with a hose attached to it. its for excess drainage.. with the moving of the refrigerator is sounds like maybe the hose can loose and causing youre puddle. I would start there first.
Jun 11, 2009 | Samsung 25.8 Cu. Ft. Side-By-Side...
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
