Question about HP Compaq 6735s Notebook
Laptop powers up but theres no display, screen blank
  • 1 more comment
  • wim3ett Jul 15, 2010
    ive tried another screen and there is still no display, also connected an external monitor and no display still, also changed the cpu, still no display, help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Lauren  Castro
    Lauren Castro Jul 15, 2010
    did you try to change the battery out?
    what do you mean by change the battery out, laptop powers up but there is no display on screen, the screen is fine, but there is no display, any help would be appreciated thanks
  • 206 Answers
I think that you need to call the manufacturer and ask if you can get a replacement screen for your laptop i think that the screen went out
Posted on Jul 15, 2010
  • Lauren  Castro
    It might be that the light bulb is out.....is it an LCD screen?OR NO?
Why is screen blank?
You never said if it worked with external monitor. You also didn't say if you tried the [fn]+[Fx] key combination on the keyboard to try and switch displays.
But, if you look at the screen closely, at an extreme angle and can faintly see the graphics then that means the backlight has blown out. For the displays with LED backlighting it's usually just a wire or circuit to repair. For the screens with CCFL (fluorescent) lighting it's a simple matter of replacing the inverter board.
Mar 14, 2016 | Samsung NP300E5A 15.6 Laptop i3 2.4GHz 6GB...
I have a dell studio 1558 laptop, suddenly while using the laptop the screen for blank so i did a hard shutdown. After that i tried starting my laptop, but there was only blank screen. I attached my...
Seems like a two fold issue here. The blank screen is possibly a faulty laptop display or inverter but the blue screen is caused by powering off the laptop whilst it was doing something and now has damaged files. With your external monitor connected power up and try to reach Safe Mode and let windows find the issue and attempt a repair or press F8 and select repair OS. When you have repaired the OS, shine a bright light at the laptop screen and see if the inverter is not running or a dead screen.
Oct 28, 2014 | Computers & Internet
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Blank screen
try to check the video card maybe it has a lost contact. try to remove it and plug it back.
Jun 16, 2009 | Dell XPS M1330 Notebook
No screen display on a first power on
The keypad was trigger.install keyboard in your laptop,because ur keypad has something wrong.
May 19, 2009 | Computers & Internet
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
HP Compaq 6735s Notebook Logo
430 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
