Question about Whirlpool Duet GHW9150P Front Load Washer
I ran my washer without turning on the water?? help
I forgot to turn the water on and the lady turned the washer on and it ran a cycle? Is that possible?
  • amanegan Jul 15, 2010
    yes thanks
    President:
  • 2,468 Answers
No,because the water fill switch would have sensed a no water or lack there of water and have not been able to close the contacts inside it to start a wash cycle
Posted on Jul 15, 2010
    what about opening the door?
  • danny Hendrickson Jul 15, 2010
    opening the door will stop all spin and drain cycles,but the timer will still time down on all other cycles,but if no water can fill the tub it will lead to stopped timer because the water pressure through the hose from the tub to the fill control via air pressure of the water pushing air pressure into the water fill control presses on contacts and closes them to operate the timer,so if no water,no water pressure to force air into the fill control,no contact movement,leads to no timer power,so the timer cannot advance into the next cycle
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
After repairing the pipeline it's inevitable that some debris/stones/cement etc. would find it's way into your machine. Even though there is (or should be) a filter in the water input hose, I'd guess that the water pressure was so high that some debris damaged the electrically operated solenoid valve which controls the water input flow. A mechanical problem then, with possibly some associated electrical fault. If you can get the machine out, I suggest unscrewing the inlet hose and having a look at the valve - they're usually easy to get to. But please DISCONNECT THE ELECTRICAL SUPPLY AND WATER first.
May 25, 2014 | Asko W6661 Front Load Washer
Lady kenmore washer
Locate contact point under the top section of washer near the lid
Dec 10, 2013 | Washing Machines
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The rinse cycle on my washer leaves soap and the spin cycle leaves water. I've decreased the amount of soap and ran through another spin cycle with no change. I ran the spin cycle while watching it and at...
Good day,
There is blockage between the outlet of the tub on the machine to the end of the hose.
First, if you have the outlet hose that is fitted into a standpipe, that could well be the problem.
In other words, there is nothing wrong with the washer, it is plumbing problem in the vertical drain pipe. Happens often.
Shut the water to the machine off, remove one of the hoses, and stick it into the stand pipe. Turn the water on. If it backs up, that is your problem.
If not, then the machine is at fault. A hose runs from the bottom outlet of the tub to the pump. Then from the pump to the outlet hose.
You'll need to remove the hoses, and pump to inspect them. It's even a possibility the pump's impeller is slipping, and lastly, check closely where the hose was removed from the bottom of the tube. Could be the classic "sock" problem.
You did not give the model. Get that information, and then type into google....................
"How to change a water pump on a ( your info) washer".
You'll get the hits you need to see how to access the pump and related accessories.
Dec 09, 2009 | Kenmore Washing Machines
We went on vacation and turned off the water.
Turn on the water, unplug machine and plug it back in.
Sep 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We accidentally ran the washer when the hot and cold water faucets were turned off. Washer ran unattended for one hour. Now the display flashes 35 minutes, the door is locked and the motor just hums when...
This shouldn't have affected any other deevice other than the water valve.
Turn water on and plug your machine back in - it should reset back to its normal cycle within 5 minutes of currency back to the board.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
Check that the drive belt is OK take it from there thenClose Ireland bye bye
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
