Question about Gateway (8008625) Cooling Fan, Heatsink With Fan
I have a Gateway MX6956 laptop cooling fan come on when computer is first turned on. It runns for about 15 seconds and then turn off not to come on again unless computer turned off and back on. Then for only 15 sec again.do I need to replace the cooling fan and heatsink or is there a problem with the motherboards chipset drivers?
james klgr
  • 362 Answers
SOURCE: Gateway 450SX4 Notebook Overheating Problem
the best thing for you to do is purchase a cooling base its a platform with fans in it to blow air through the laptop all the time. these are greast for the newer faster machines they tend to run hot. you will also love the difference it makes in performance
Posted on Dec 11, 2008
  • 166 Answers
SOURCE: Gateway 831gm not booting. Fans come on but no boot process.
2 questions:
When you say new motherboard do you mean an actual new motherboard or new to that machine, but came from another used model?
When you say you tested the power supply do you mean with a voltmeter/ammeter or put it in another computer and it worked?
I worked on several gateways with similar problems and it boiled down to motherboard issues.
I tested it by replacing the power supply with a bigger (used) power supply and it worked great (for 1 time) and then put the other power supply back in to confirm my diagnosis and yep it wouldn't boot. The next morning I was going to run some virus/malware cleanup and installed the other (known good) power supply and it would not work. I tried all day to get it to boot and it did about twice in a 4 hour period. When it did run it would run great but any attempt to restart it would cause it to crash. No ryhme or reason, it would not fail the same way more than twice. Sometimes beeps, other times no beeps, sometimes it would start up with no video (could hear the Windows starting sounds) other times it would start up normal. I could let it sit and it would start or I could keep trying in sucession and it would eventually start. Some times the fans would slow down from a roar, sometimes they wouldn't. So with a known good power supply that had 150 more watts than the original I diagnosed it as a failed motherboard. But if you have put in a brand new motherboard then I would replace the power supply, because a bad power supply does not mean no power, just not enough power. Please post back and let us know what you find out.
Posted on Mar 31, 2009
SOURCE: gateway gt5648e desktop power
I had temporarily solved this problem on my PC. After much research I've learned that Gateway shipped these PC's with faulty bios. What you will notice is that your machine will "loud fan reboot" every hour like clock work. Either clock in manually or use your system tools to see the exact reboots and manually reboot a minute before it shuts itself down. This has worked for myself and many others on various boards if you google the problem.
Weird? Yes!! But it worked !!! 2 months reboot free.
Posted on May 05, 2009
Geekman
  • 32281 Answers
SOURCE: when I turn on my computer, the screen stays black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 10, 2009
  • 1768 Answers
SOURCE: cpu cooler for gateway has just heatsink want to
You need to see if the motherboard is compatible with active cooling other wise it will not work.
Posted on May 01, 2010
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Jan 16, 2013 | Gateway NV5378u Notebook
I have a Gateway MT6840 and when I turn it on it saying check main fan and second fan error what do I need to do?
There is a cooling fan issue that needs to be looked at quickly, I recommend a professional to assess.
May 02, 2012 | Gateway Computers & Internet
How to increase max vol further on, of my laptop gateway mx6956 as it is horribly low
Hello, You can increase the volume of your laptop by, first check the speaker and headphone icon whether it is set to 100%.You can see it in the system tray or by the right hand side at the bottom of your screen or at the control panel,click on SOUND and increase the volume. Note the software you are using like window media center, VLC player, real player and the likes should also be increase to maximum, then if your computer has an external control for the volume, make sure you increase it to the maximum. HOPE THIS HELPS
Nov 23, 2010 | Gateway MX6956 Notebook
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
Gateway MX6956 screen flashes when dc adapter plugged in...hard t
The jack is soldered to the mo bo. If that is the only thing wrong all you have to do is open up the unit carefully, get access to the mo bo, resolder it and reassemble everything. A real PIA job but do able. Good luck
Sep 18, 2017 | Gateway MX6956 Notebook
92 chevy lumina euro cooling fans kick on when code scanner is attached i replaced the cooling fan switch just below the thermastate houseing and still dont work. If i unplug it from the sensor they will...
When everything starts doing random acts on their own the first thing you always check and ensure. That will be all points of grounding of the componants.
Nov 06, 2009 | Chevrolet Lumina Cars & Trucks
Gateway 7410 laptop keeps on turning off after complete boot. The cpu fan speeds up and after a few seconds the laptop turns off
Could very well be that it is getting hot. If the cooling system is plugged, there is no air movement, and this would make the fan speed up as the temp rises. Shut the laptop down, unplug from a/c adaptor, remove battery, and try blowing the cooling system out from the outlet to the fan with a can of air. You might want to stick a paperclip or the like in to stop the fan from spinning.
DO NOT USE AN AIR COMPRESSOR AS THAT AIR IS MOIST.
Mar 17, 2009 | Gateway MT3705 Notebook
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Gateway (8008625) Cooling Fan, Heatsink With Fan Logo
143 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
