Question about Vacuums
My Bissell proheat carpet steamer is not dispensing any liquid. The red spindle visible from top view is not spinning and the belts appear to be in tact. Can you tell me what's wrong?
    President:
  • 1,673 Answers
Does liquit squirt out of hose, if it does, the heater inside the handle asm. may be clogged. If not, then is the pump belt ok, is the gasket on the bottom of the tank(on the vavle) on or is it sitting in the hole or missing? It needs to be on the tank. May have a bad pump.
Posted on Apr 20, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
The unit does not put any watter on the carpet and when I push the triger the red spinner does not move. The tank is full of hot watter
This sounds like your pump brush belt is broken in your Bissell. The belt controls the pump in the machine, as well as the brushes. This would be explain why the solution is not spraying, as well as why the red spinner on the top of the machine is also not spinning.
Here's an extremely helpful video that you can watch on how to replace the belt on your Bissell ProHeat Carpet Cleaner.
If you open up the door and find that your belt is not broken, please just reply using the Clarification Request form here on the Fixya website, and I'll be more then happy to do some advanced diagnosing with you to figure out what the problem is.
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt:
http://www.bissell.com/VideoRating.aspx?id=1555
If this information was helpful to you, help other Fixya users with the same problem find this video by clicking the very helpful four thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat 25A3/64D9 series - cleaned one rug - now the wheels won't turn and it looks like the belts are on ok. What else should I look for?
I had the same problem. I found that when I took the belt door off, the belt was fine. I turned it over and took the red retainer arm out and then removed the screw on the white brush holder, the toothed belt was fine also. Somehow the machine had grabbed a carpet cord and wrapped it around the pulley where the toothed belt and the flat belt both attach. The spindle just wouldn't turn. After removing the carpet thread, everything worked fine again.
Jan 07, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell shampooer 1697-W. Will not dispense water to shampoo carpets....
That means that the pump belt is worn and needs to be replaced. Here is the belt you need and a manual you can view:
Bissell Proheat Belts and Manual
Dec 13, 2009 | Vacuums
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
69 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
