Question about Palm TX Handheld
Is there anyway to delete programs from a Palm TX.i want delete some applications from my palm.
In home mode tap on time at top right. new menu will appear with apps/options. under apps menu will be several options. tap delete to bring up list of apps on palm and then find file to delete and tap on it and hit delete at bottom then done. that's it!
Posted on Jul 20, 2010
  • captobvs Jul 20, 2010
    i meant top left :( my bad
I lost the Application feature on the Palm TX.How can I restore it back?
Do you know how you lost it? It should be hard programmed in the palm. It should be accessible by pressing the home key once or twice.
If I'm misunderstanding you and Application is an icon that you haven't personally deleted then your handheld may be in a different category than what you want. Tap the word at the top righthand corner of the screen and a drop down menu should show itself. Tap the top option which should display all icons installed (but not on a SD card) and hopefully that'll get things cleared up.
Hope this helps!
Dec 30, 2009 | Palm TX Handheld
Using the desktop, is there anyway to move(either to the memory card or the PC) or delete files on a Palm TX. I apparently used to much of the devices memory and now I can't ge to the home screen(it...
If you're able to hotsync, then yes. In the desktop, delete notes or other items (Does the TX have voice memos? Those would be a quick way to free up a lot of space!)
Perform a hotsync, and your Palm should then have some free memory.
If you're not able to hotsync, then nothing you do in the Desktop will have any effect on the Palm.
But, I'm skeptical that this is the real problem. It sounds more like memory corruption, and a hard reset is going to be the real fix.
Sep 14, 2009 | Palm TX Handheld
Is there anyway to delete files from a Palm TX using the desktop?
Unless I'm not understanding your question, any entries that you delete from either the desktop or PDA will delete from the other device when you sync your PDA.
So, if you delete an item from your Palm desktop, the next time you sync your PDA to your desktop, the entry will be deleted from your PDA as well.
But, if you haven't backed up / synced your PDA to your desktop yet, install and run Hotsync Manager - do that first. And, perform that procedure often so that your info on your PDA will be safe on your desktop.
Hope this helps.
Is there anyway to delete programs from a Palm TX from the desktop?
HI,
Yes there is a way to delete programs. Take your TX and in the upper left of the screen you will see the time. Tap the time with your stylus. A drop down menu will appear. Tap "DELETE". Your TX will generate a list of all the programs and applications on your hand held. Once that list is generated tap or highlight the one you want to delete and the tap the delete button at the bottom of the screen. Once you have deleted all the programs you want tap done and then do a hot sync. They should be gone from then on. If you find this helpful please rate me. Best wishes.
I originally tried downloading a program without enough memory on my palm. If failed and now there is insufficient memory to open normal applications. I tried to sync it, but it now fails everytime and I...
Just a thought, try deleting other programs, pictures, etc. to free up some extra space, then try to delete them again. It could simply be there's not enough room in memory at the moment. And if it's an option, I would use uninstall instead of delete. Good luck.
Sep 17, 2017 | Computers & Internet
Palm keeps retting.
I followed the instructions posted by bab2000 in brighthand.com. I pressed the UP scroll button and then press and release the reset button. It took awhile and several tries but it worked. I then hotsynced and voila I am enjoying my palm TX again.
Thanks.
Aug 15, 2008 | Palm TX Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Palm Tx crashes constantly when I do search on Contact
You should restore your Palm software.
Have you docked it recently?
Jun 15, 2008 | Palm TX Handheld
Uninstalling program from the computer?
  1. Go to Applications 650_app.gif (info).
  2. Open the Menus 650_menu.gif (info).
  3. From the App menu choose Delete.
  4. Tap the name of the application you would like to delete.
  5. Tap on the Delete button. Tap on the Yes button to confirm that you wish to delete the chosen application.
Delete programs from your Z22 by using your Z22 and not your computer
Jun 05, 2008 | Palm Z22 Handheld
Palm TX reboot
What happens when you press the reset button on the back of the TX?
May 13, 2008 | Palm TX Handheld
Palm TX Handheld Logo
188 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
