Question about Nikon D40x Digital Camera
Dropped my nikon d40x and now shutter feels like its slow and pictures are blurred. Is repair possible and how much
Unscrew the 8 screw at the buttom of your camera. take the batt out. and unscrew the 2 remaining screw. take the cover off and youwill see a red plastic wheel. rotate the wheel back and fourth, put the battery back and hold it press it so the camera will have power turn the camera on and press the button while moving the red wheel and it will take pictures and you solve your problem.
merwyn yap
Posted on Aug 11, 2010
I recently dropped my nikon D40X and now every picture on every setting Is very dark. I also get error message to press shutter again sometimes.
Hi, What setting is the camera on now? As well have you tried other settings? Does that do anything?
Jun 19, 2011 | Nikon Cameras
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
Blurred pictures, and Red hand Flashing warning
The red hand is warning you that the shutter speed is too slow for handholding. Your pictures are coming out blurred because the camera is moving during the relatively lengthy exposure.
Put the camera on a tripod or other stable surface, and/or use the flash.
Dec 02, 2009 | Nikon Coolpix 3200 Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
Nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
Apr 04, 2009 | Nikon D40x Digital Camera
Flash doesn't work
check the flash settings.. it just might be on 'Slow or Rear' flash mode. good luck!
Nov 08, 2008 | Nikon D40x Digital Camera
Shutter Speed too slow on indoor sports for Nikon D60
Maybe. Assuming you can't add more light, you can either increase the ISO and/or open up the aperture. Try going to A (Aperture) mode and opening up the lens all the way. This will give you the fastest shutter speed possible under the conditions. That may or may not be fast enough.
Nov 02, 2008 | Nikon D40x Digital Camera
Dropped my Nikon D40x, Pictures dark, won't let me go into manual settings.
You will need to send it to Nikon to get the camera checked out - there is nothing user-serviceable that you can do.
Basically, you have broken it. Take more care with your expensive toys... use the strap, buy a silicone jacket, etc.
Oct 22, 2008 | Nikon D40x Digital Camera
Nikon d40x shutter problem
May be a weak subject to focus or the flash is not ready when you press the button.
Set the camera to auto(green) mode.Try it with a contrast bright subject for as many time as possible.
If the problem persists turn off the camera and reset the camera using the button near usb connection.
Then go to seller for replacement.
Mar 17, 2008 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
325 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
