Question about Xerox Phaser 6300DN Laser Printer
No display on lcd screen, only solid red light, no
No display on lcd screen only solid red light no noise from printer when on.
  • 506 Answers
Does the printer print? if yes and the printer is still under warranty, send the printer in for warranty repairs. The interface card may be faulty or the interface robin cable if the printer is printing.
Posted on Jul 15, 2010
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Kyocera not feeding paper.
Open paper tray, locate the feed roller (small rubbery wheel) and moisten a cloth. Gently clean the roller to remove build up of paper dust from it.
Also worth using is some "anti static foam cleanser" on the cloth to help deep clean the rollers, or the pre-moistened "Screen wipes"
Also check there is nothing blocking hte paper path, remove paper cassette, and toner catridge (and drum if I recall correctly) and see if you can feed a sheet of paper MANUALLY from tray up into the "imaging chamber" where the toner lives. If this feels too stiff, there could be an obstruction in the way, fragment of paper scrunched up after a REAL jam, or fault sensor arm.
If you find something and can remove it, reassemble, and test
Dec 10, 2014 | Kyocera FS-4000DN Laser Printer
Proscan tv power light blinks red and won't turn on, it normally is solid red when off and turns blue when on. whats wrong?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 28, 2014 | Proscan 42LA45H 42 in. LCD TV
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
No Display
in response to the previous response, does the printer have to be under warranty to receive the free replacement?
Jun 02, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 6300DN Laser Printer Logo
640 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
