Question about Xerox DocuColor 12 Color Copier
SHIFT YELLOW - Xerox DocuColor 12 Color Copier
    Champion:
  • 241 Answers
Its problem with ur drum cratriage assembly
try with another cartriage
Posted on Oct 05, 2010
Shift stuck in park, the yellow release tab didn't work, yellow tab came off!!!!
Make sure the brake lights work, if not the park release electric solenoid is not powered and you can't shift out of park.
Oct 25, 2016 | Mini Cars & Trucks
Bizhub c8000 code C-2211
Yellow Drum Motor, is the yellow drum seated properly, switch drums does code shift, drum shaft damaged, worse case bad yellow drum motor and $$$$$$$$$$ Control board
Feb 08, 2013 | Genuine Konica Minolta Konica Minolta...
I need to know where the shift key is on the TI-30IIS
If you mean the TI-30X IIS then the shift key is the yellow one in the upper left corner of the keyboard, marked "2nd".
Feb 18, 2012 | Texas Instruments TI-30 XIIS Calculator
I have a 2001 saturn 5 speed...what is the yellow arrow that appears on the dash display while im driving?
that yellow arrow is either telling you to shift up a gear or go down a gear.
Feb 14, 2012 | 2001 Saturn L-Series
How do i change the number of decimal points on the calc from 4 to 2?
Press left-shift [DISP] 1 2.
left-shift is the yellow key below the EQN key.
DISP is the left arrow key.
left-shift [DISP] brings up the display menu, 1 selects FIX, and 2 specifies the number of decimal digits to the right of the radix point.
Jan 28, 2011 | HP 35s Scientific Calculator
I have a Konica Minolta BizHub C252. In the bottom of my screen on the machine it has a triangle and once I tap it it brings me to another screen and it says: Machine status P 8 P 21 I have no idea what...
P-8 is for yellow imaging unit failure. P-21 is for Color Shift Test Pattern failure. The P-21 Color Shift Test pattern failure is probably being caused by the Yellow Imaging Unit Failure. Basically, I think your issue is with the yellow imaging unit. If you are experianced with these then you could try removing and re-installing the yellow imaging unit. You may have to replace it. I would certainly start there. Or if you have a service agreement then call them out for repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Can not place from park to drive at grear shift
try replacing the neutral safety switch.
Jan 02, 2010 | 2004 Ford F150
Cant get 2006 sprinter to shift out of park
check the switch on the brake pedal ,needs to be cleaned or replaced
Jun 15, 2009 | 2004 Dodge Sprinter
Factorial of numbers
Look above number 4 there should be 'n!' in yellow color that is the factorial so just type 20 then shift 4, shift is the yellow button in the top left. Hope you find it.
Jun 01, 2009 | Sharp EL-531VB Calculator
Can't shift out of park
It's possible the shift lock solenoid, the wiring, or the fuse is bad.
Bret
RepairPal.com
Jul 06, 2008 | 1991 Volvo 240
Xerox DocuColor 12 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
