Question about Siemens WD61392GB Front Load Washer / Dryer
No water when start button is pressed water is not taken into the machine
When start button is pressed water is not taken into machine
Posted on Jul 15, 2010
I have a whirlpool wwi851ew , when I press the necessary buttons to start the machine it starts to fill when I press the start button, the problem is keeps draining the water out of it, does anyone ha
check the vacume pipe ....remove lid.......look for thin black white or clear pipe coming from the drum to a small round plastic part........when water level rises the vacume created closes a switch to stop water and start machine..
cheers
Nov 01, 2014 | Whirlpool Washing Machines
Just installed a new motor controller module fuse kit and washer flashes it it stuck in wash cycle
usually they need to be sized, hold temp button down and press the on button at the same time machine will give 4 short beeps release, depending on machine size you have press temp up for 5.5kg water leel up for 6.5kg or spin speed up for 7.5kg turn off and on again the power button and your ready to go
Oct 15, 2014 | Fisher and Paykel GWL11 Top Load Washer
When pressing the "start/stop' button
the pump is not getting water, make sure it does
Nov 11, 2017 | Nuova Simonelli Mac 2000 I Group Espresso...
How to descale machine-is there a video showing how? I have the Saeco Magic Comfort + machine.
Hi
I put this next statement in so your machine will last longer.
Enter the menu by pressing the menu button. Scroll down until you reach "water hardness" and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to "Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Feb 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
We dont have a manual for our Saeco Magic comfort coffee machine and the declcify message is up on the screen. What do we do?
Hi
Enter the menu by pressing the menu button. Scroll down until you reach “water hardness” and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to “Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process andwhen it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to “reset descale”, push the enter button and chose “Yes” and push the enter button. Now it will tell you we next to be descaled.
Apr 20, 2010 | Saeco Magic Comfort 103467 Espresso...
Kenmore Elite smartwash QuietPak9 F H error code
Press the Pause/Cancel button twice to clear the display then check if water is introduced into the machine. Drain the water from the machine by selecting Drain and Spin then pressing the Start button for one second. Empty the machine after the water is completely drained.
Start a new cycle with Hot/Cold water temperature and check how long before the error code appears after the cycle is started. When the code appears, press the Pause/Cancel button to clear the display then check again if water is introduced into the machine.
The pressure switch is not tripping and must be replaced if the error code appears about 8 minutes after the cycle is started and about 40 liters of water is introduced into the machine.
The flow meter is not working if the error code appears less than a minute after the cycle is started and about 3 liters of water is introduced into the machine.
The valve solenoids may not be working or the levers are stuck if the error code appears less than a minute after the cycle is started and no water is introduced into the machine.
Let us know which case above is observed for specific troubleshooting and repair guide.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Walter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Sep 24, 2008 | Saeco Vienna Espresso Machine
Trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Dec 30, 2007 | Gaggia Titanium Espresso Machine
Siemens WD61392GB Front Load Washer / Dryer Logo
308 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
