Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
-6x^3+2x^2+48 factor - SoftMath Algebrator - Algebra Homework Solver (689076614429)
My ti 89 won't factor
The polynomial cannot be factored in the set of Real numbers: The roots of the polynomial equation are complex.
You should use the command cFactor( found under F2:Algebra> A:Complex>2:cFactor(
However, you should set the Mode Complex>Rectangular, and the EXACT/APPROXIMATE mode to Exact, otherwise your roots will be in decimal representation.
Jan 01, 2014 | Texas Instruments TI-89 Calculator
Need to factor x^2-6x-7 0n my Ti-84
This quadratic expression have two zeros, 7 and -1. Than you can write this as (x-7)(x+1)
Mar 26, 2013 | Texas Instruments TI-84 Plus Calculator
6x squared - 10x =0
Factor out 3X
3X(2X-5)=0
The expression is equal to zero if one of the factors on the left side equals zero.
1st solution: 3X=0, thus X=0
2nd solution 2X-5 = 0 if X=5/2
Sep 10, 2010 | Office Equipment & Supplies
. x^3 - 4x^2 - 12x
Hii,you can use the following solution x^3 - 4x^2-12x=0 x(x^2-4x-12)=0 replacing -4x from -6x+2x x(x^2-6x+2x-12)=0
Now Factoring x(x(x-6) +2(x-6))=0 x(x-6)(x+2)=0 Solution is x=0, x-6=0,x+2=0 1) x=0 2) x-6=0 =>x=6 3) x+2=0 =>x=-2
May 05, 2010 | Vivendi Excel@ Mathematics Study Skills...
Factor 6x^4 - 6y^4
6x^4-6*y^4=6 (x^4-y^4)=6(x-y)(x+y)(x^2+y^2)
Apr 01, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Find the value of the variable ''x'' 6x+6=4x+12
6x+6=4x+12
Since 4x contains the variable to solve for, move it to the left-hand side of the equation by subtracting 4x from both sides.
6x+6-4x=12
Since 6x and -4x are like terms, add -4x to 6x to get 2x.
2x+6=12
Since 6 does not contain the variable to solve for, move it to the right-hand side of the equation by subtracting 6 from both sides.
2x=-6+12
Add 12 to -6 to get 6.
2x=6
Divide each term in the equation by 2.
(2x)/(2)=(6)/(2)
Simplify the left-hand side of the equation by canceling the common factors.
x=(6)/(2)
Simplify the right-hand side of the equation by simplifying each term.
x=3
Good Luck
Sep 10, 2009 | Audio Players & Recorders
Can you Factor on a TI-84? IF not, does the TI-89?
Well, to answer part of your question, yes... the TI-89 does factor like this. it is inputted like this:
factor(6*x^2+11*x+4,x)
Check the catalog in the TI-84 (which is 2nd-zero) and look under F for factor()
Jan 12, 2009 | Texas Instruments TI-89 Calculator
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 31, 2008 | Cameras
Computers & Internet Logo
18 people viewed this question
Top SoftMath Computers & Internet Experts
k24674
ali_zulfikar
ali_zulfikar
Starnley Johnwells
Starnley Johnwells
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
