Question about GE Refrigerators
Water flow is extremely slow after filter change.
Hi, I have a GE Profile PSS26NSTESS Side-by side. I've had it for about 3 years. Everything was fine until my water filter light came on about 4 months ago. I bought a new filter, replaced it and now the water comes out in a slow dribble. It takes about 3-4 min to fill a glass. I thought it was the filter, returned it; got another one and still have the same problem. If I take the filter out and empty it. Then it actually works good for a couple of minutes. Please help!
  • 57 Answers
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
Posted on Jul 16, 2010
  • tampaworth Nov 21, 2010
    Hi gil068
    We have the very same problem with a GE Profile 2005 model side-by-side. All was cool until filter replacement about 6 months ago, then the exact thing you experienced. Did you find a fix? Please let us know if you can at tampaworth@msn.com. Thank you.
    Hi gil068
    We have the very same problem with a 2005 model GE Profile counter depth side-by-side. Replaced the filter about 6 months ago and ever since, dribbling water or none at all. We replaced the filter like you with the same depressing results. Did you ever find a fix?? Please let us know and thank you.
GE side by side water dispenser not working very well.
you need to change the filter, located in upper right hand corner of fresh food section. Order it at geappliannce.com
Oct 10, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile side by side with water and ice in the freezer door, it is about 3 1/2 years old. The water was barely coming out of the dispenser, I changed the water filter and it is not any better -...
We had this problem on our own fridge at home. it turned out the plastic lines which feed these appliances liable to fill up with lime and calcium which will restrict water flow. take a look at getting a new line.
something else to look at. is the tube getting kinked when you push the fridge into postion?
let me know if this helps. davcol47@hotmail.com
May 08, 2010 | GE PSC23NSWSS Profile Counter-depth 23.2...
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Feb 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water coming from the dispenser is very slow
hello from fixya,most important is the supply shut off the water undo where conects to the refer.put inside a bucket/pot and turn on water you should have a great flow.if ok there you could move to filter but the water valve could have a mineral blockage and is harder to test.you would have to undo the out put side of the chilled water then hit the water cradle.etc.. on the ice maker.also a thought.if ice small and water slow.may be filter if had good house supply.hope that helps.God blessyou house,tom
Jan 02, 2009 | GE Profile PSW26P Stainless Steel Side by...
No Water or Ice
It sounds like a control board problem. When you push in the paddle does the fan in the freezer slow down? If so you need the control board on the back.
Apr 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
260 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
