Question about Haier Heating & Cooling
How do you take front off of older haier window unit
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. Most have two clips in the bottom and you have to pull ot on it and the clips release. Some have screws in the front cover either behind the filter grill or inside the control panel. If there is no screws here then there is just two clips in the bottom that hold the front on.
Posted on Jul 15, 2010
Removal of front panel on Haier window unit
There's 2 plastic clips that hold the top of the front cover to the metal, about 2-3 inches from the outside, on each side. Pull away the bottom several inches and push down on the metal while pulling on the plastic.
Jul 30, 2016 | Haier 5,000-BTU Mechanical Window Air...
Won't change from fan mode
you more than likely need a new control board or front display control board
Aug 09, 2013 | Haier Heating & Cooling
My unit requires remote control to operate remote control is lost what 2 do
Whether you have a thru the window model or a potable AC, the same controls that are on the remote are on the face of the unit. To operate it without the remote, turn the unit OFF and unplug it. Wait 5 minutes, then plug it back in. Wait 3 minutes & turn the unit ON using the controls on the front of the unit.. The controls will have reverted back to the original factory settings and you can now use the front control panel to operate & set the controls as you like.
If you want to purchase a new hand held remote, contact Haier Product Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 02, 2011 | Haier Heating & Cooling
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
My Haier spits water out the front of the unit it drips for long period of times of and on .
Take a level and place on top of unit front to back. Should be 1/4 bubble toward back.
Also purchase "Slime-Out" tablets to remove gunk.
Nov 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
How to remove plastic front to clean
I will tell you that every brand has a different way of removing the front face cover. I sell the Haier Central Heat Pumps and Air Condioners and repair window units. Click Here for the user guide=> HWR10XCA
Most fronts come off after pulling the front cover facing from the top as the bottom is sitting into clips. Most are but you removed a screw fromsomewhere and it just may be only one tha keeps it snug so the cover will remain firm. Here is a link to=> Haier America and thier contact link=> Contact Us and their=> Hot Line
AMERICA & AUSTRALIA U.S.A. & Canada All Haier Products
Hotline : 1-877-337-3639 Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
May 09, 2010 | Haier HWR10XCA Air Conditioner
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Haier hwr10xc6 thru-wall/window air conditioner
Does the unit have an energy saver or timer feature? It should be on the top front panel of your unit. If so, read and follow the directions in your manual. If you still have problems, contact Haier at their toll free Customer Service helpline.
Apr 25, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
