Question about Whirlpool Ovens
My Ikea-whirlpool oven door exploded! I was baking a kake, and after 10 min the outer glass blew up and desintegrated! The kitchen was all full of broken glass. The oven has 2 years of a 5 year warranty. But Whirlpool says it's not covered by warranty!what can I do?
SOURCE: Whirlpool GBD307PDS7 control panel doesn't light, glass exploded
Just venting
Posted on Apr 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Whirlpool Oven Glass just shattered
This is a very common problem with the majority of electric ovens, there is no one particular reason for it to happen, it just happen's.
You have no alternative but to replace the glass, check your household insurance policy, as some policys cover for breakage of glass.
Please` rate my solution.
Thanks.
Posted on Jul 29, 2009
  • 3600 Answers
SOURCE: loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Posted on Aug 07, 2009
SOURCE: Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Posted on Aug 25, 2009
SOURCE: my name is jason and my oven glass door just
We had exactly the same thing happen to us, again our is 2 years old, and was fitted by persimmon before we moved in.
Seems to me that it may be a fault.
i tried calling whirlpool but they was having none of it - we got a local company in to change the glass.
this cost us just over £100.
was right before christmas so could of done without.
I'd be interested if this has happened to over as well.
Posted on Jan 18, 2010
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
The outer glass of my oven door shattered, can I still use it until it is repaired?
Hello- I would be careful using the oven mostly because the inner glass will be VERY hot to the touch, meaning you will get burned if you touch it. If you have children I would refrain from using the oven, too risky. If it is just you, or just adults then you should be ok to use it until you can repair it. Keep in mind that you will probably lose a lot of heat out the door and it make take longer to bake. Again, be wary of the inner door glass if you use the oven. Do a test run with a low heat and see how it performs. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
Whirlpool glass door exploded in my face! A serious defect!
I would go to a Lawyer unless you have a serious voltage problem. Whirlpool makes pretty good appliances. To have probems with all of them is very unusual. Look for a comon problem. You have not stated your outher problems. I have heard about oven glass breaking with no reason.
Sep 21, 2009 | Whirlpool GBD307PDS Electric Double Oven
HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Aug 17, 2009 | Ovens
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Ovens Logo
317 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
