Question about Amana AAC051FRA Air Conditioner
I need a control knob - Amana AAC051FRA Air Conditioner
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
Where is the air and heat blend motor on a 2000 dodge dakota?
Hi Sharon, I'm glad to help. Your 2000 year doesn't have a motor for the temp door. It operated by a cable running from the control head to the temp door and you work it manually. If you can't control the temperature from hot to cold, sometimes the cable come off or breaks. Here how you can see the cable to see if its working. Remove the radio and right behind it you will see the cable attached to the door, while watching it move the temp lever from hot to cold and watch it. If it is moving then its most likely out of ajustment. If it is not moving, then you'll need a new cable. Just in case it is moving, I'm attaching the instruction on how to adjust it below. Hope this helps and have an awesome day Sharon!
TEMPERATURE CONTROL CABLE
Any time the heater-A/C control or the temperature control cable are removed and/or replaced, the following procedure must be performed.
  1. The temperature control cable housing and core must be installed at both the heater-A/C control and the heater-A/C housing ends, and the heater-A/C control must be installed in the instrument panel. See Heater-A/C Control and Temperature Control Cable in the Removal and Installation section of this group for the procedures.
  2. Rotate the temperature control knob on the heater-A/C control so that the knob pointer is in the 12 o'clock position.
  3. Pull the temperature control knob straight out from the heater-A/C control base until the perimeter of the knob (not the knob pointer) protrudes about 6 millimeters (0.25 inch) from the face of the control base.
  4. Rotate the temperature control knob to the 1 o'clock position. Push in on the knob slightly and continue rotating the knob to its full clockwise stop. The knob pointer should be aimed at a position about 8 millimeters (0.315 inch) beyond the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If the knob is not pointed to the correct position, go back to Step 2 and repeat the adjustment procedure.
  5. Rotate the temperature control knob counterclockwise until the knob pointer is in the 12 o'clock position again.
  6. Push the temperature control knob straight in towards the heater-A/C control base until the perimeter of the knob (not the knob pointer) is flush with the face of the heater-A/C control base.
  7. Rotate the knob to its full clockwise stop again. The knob pointer should be aimed at the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If OK, go to Step 8. If not OK, go back to Step 2.
  8. Rotate the knob to its full counterclockwise stop and release the knob. If the knob springs back from the counterclockwise stop, the self-adjuster clip that secures the temperature control cable to the blend-air door lever is improperly installed. See Temperature Control Cable in the Removal and Installation section of this group for the procedures. If the knob does not spring back, the temperature control cable adjustment is complete.
May 14, 2014 | Dodge Dakota Cars & Trucks
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Heater controll switch
Hello, I want to tell you about some of the knobs for the temperature control switch, if that is the switch you are referring to.
The way some of the knobs are made, they have a 1/2 moon shape with a metal clip inside them on the backside of the knob. The 1/2 moon shape is also present on the control shaft the knob fits onto. When the knob breaks and splits, the knob rotates around the temperature control shaft without moving anything. From the driver's view, the knob is normal.
You would need to pry off the knob and inspect it, then rotate the temperature control shaft with your fingers or lightly grab it with pliers.
Jan 30, 2014 | 2004 Ford E-350 Super
Problem with washing maschine temperature control knob
It depends on whether the knob is slipping or that the contacts are working within. Please check and see if the controls can be moved further and the temperature cuts off earlier than 90. If so the control and the thermocouple is working and the external knob needs to be replaced
Jan 20, 2013 | Washing Machines
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Heater Fan does not work
Sounds like the fan control knob has shorted out. You can check the fan "blower" relay and fuse in the engine compartment but you need to make sure the control knob is good or you will keep blowing fuses and relays. If your blower fuse and relay are good, then just have the control knob checked and replaced if needed.
May 08, 2009 | 1999 Volkswagen Passat
Fan control knob has only two speeds, ''Off'' and ''high.'' Can knob be replaced or do I need replace complete control unit.
there is no computer control unit, what u need to replace is the fan speed control resistor module.
Mar 22, 2009 | 2001 Dodge Dakota
I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Jul 05, 2008 | Fedders AEQ07FBG Air Conditioner
CD volume
Select the source to adjust
Press the [SRC] button.
2 Enter Audio Control mode
Press the Control knob.
3 Select the Audio item to adjust
4 Adjust the Audio item
Turn the Control knob.
S Exit Audio Control mode
Press any button.
Press a button other than the Control knob or ...
button.
1 Select the Basic Audio item
For how to select Basic Audio items, see <Audio
Control> (page 6).
2 Enter Detail adjustment mode of Audio
Control
Press the Control knob for at least 1 second.
3 Select the Detail Audio item to adjust
4 Adjust the Detail Audio item
S Exit the Detail Audio Control mode
• When you set the Bass Extend to ON, low frequency
response is extended by 20%.
• You can exit the Audio Control mode at anytime by
pressing any button except for Control knob or ~
button.
http://akamaipix.crutchfield.com/Manuals/113/113MP338.PDF
page 6 and 7
May 06, 2008 | Car Audio & Video
Amana AAC051FRA Air Conditioner Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
