Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
My kitchenaid dishwasher model KUDD01DPPA wont stop running the light is also redand how do we remove the bottom drawer
SOURCE: Dishwasher stopped working. Suspect electronics issue.
An expert from another site says it's a faulty control panel and may need new actuators.
Posted on Feb 01, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Posted on Jun 11, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
  • 1382 Answers
SOURCE: Kitchenaid KUDS01FL -Dishwasher -
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Posted on May 20, 2010
Testimonial: "SOLVED THE PROBLEM"
ginko
  • 19396 Answers
SOURCE: Model KUDD01DPPA KitchenAid dishwasher Error:
Hi.
You can find parts and diagrams for this model here.
Alternatively here: KUDD01DPPA0.
About the problem, the inlet valve and hose is single, therefore the valve is working.
Check the inlet hose setting. Check pressure from lines.
Check the fill hose for the upper drawer. That is likely causing the problem.Check the fill hose in the link assembly, and the valve Check in drain (Fill hose for upper drawer is 4 here).
Regards.
Ginko.
Posted on Apr 13, 2011
My double drawer kitchenaid dishwasher sold red light and beeping during cycle wont turn off and runs even with door open, turned breaker off
If you using upper or lower drawer and this shows up it means the dishwasher has water under the filter board which located on the bottom under the lower drawer. You have to disconnected power,removed the lower drawer, clean the water, replaced filter board, check the dishwasher for leaking.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 26, 2017 | KitchenAid Dishwashers
I have a two drawer KitchenAid KUDD01DPPA. Upon pushing the start button on either drawer the dishwashers will start. then within a minute they turn red and beep non stop and the dishwashers do not run
Usually this indicates a leak. Open the bottom drawer and look underneath and behind it in the base of the frame and see if there is water sitting in there. If so, dry it out with towels. Once all the water is dried out run the dishwasher again. If the same thing happens and the water returns you will have to find the source of the leak. Sometimes its just a temporary leak from a tall item obstructing the lids from closing and sealing all the way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Feb 27, 2015 | KitchenAid 23 in. KUDD01DPPA Stainless...
Have a kitchenaid double drawer dishwasher. While running the bottom drawer the top drawer fills up with water. Had the filler valve on the garbage disposal changed. Issue still continues. Any suggestions
Mine does the same thing! (Same model) I've finally discovered that if I start the bottom drawer first and the top drawer just after that doesn't happen as much. Also, if I run the garbage disposal (and water obviously) while it's starting (I will try to do my hand washing while the dishwasher is getting going) that seems to keep this from happening as well. I've given up running just one drawer, which totally defeats the purpose of buying the 2 drawer dishwasher. But it does keep me from having to bail the bottom drawer :-( I'd like a better solution to this too!
Sep 10, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kitchenaid dishwasher wont stay closed
you might need a new Latch, Drawer (left Hand) part number 8194053 okay
Feb 07, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Won't run unless i push ******* the drawer
On the right side of each drawer, near the top is an optical sensor (light pipe) that reflects infrared light of the side panel to indicate proper door closure. I f the unit is not aligned/installed properly the sensor will not sense proper door closure.
Mar 06, 2012 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kitchenaid dishwasher KUDD01DPPA0 lower drawer has no lights on start/stop badge and that drawer will not run.
hello, this is the schematic for your entire machine in case you ever do need it http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDD01DPPA0/0593/0130000?pathTaken=&prst=0&shdMod=KUDD01DPPA0 in your manual it would say what the start stop badge means If this unit is new do not attempt to repair the unit as it would be warrantied and you would void your warranty and I think it is still warrantied seeing how there is no manual online available yet if your unit is not warrantied and you require further diagnosis please message me back and I will look further into your situation Thanks Rick
p.s the stop badge could mean you have a blockage in your drain area but need clarification on your warranty information first Thanks again Rick
May 19, 2011 | KitchenAid 23 in. KUDD01DPPA Stainless...
Model#KUDD01DPPA Both Drawers keep reverting to light/china error code
Hi. I have the same problem. Were you able to find a solution? This error code means "motor failure". But how can both motors fail at the same time?
May 14, 2011 | KitchenAid 23 in. KUDD01DPPA Stainless...
Both drawers are stuck in the on position, both
The water sensor is malfunctioning. It believes that there is still water, so the pumps run and the washer will not continue on its cycle. replace the water sensor, or dry it out so it functions properly
May 15, 2010 | KitchenAid 23 in. KUDD01DPPA Stainless...
Jan 31, 2009 | Dishwashers
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
265 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
