Question about Garmin nuvi 255W GPS Receiver
GPS is 1.5 years old and it stopped working. It won't turn on, even when plugged into the car charger. Could this be a connection or battery issue?
  • Garmin Master
  • 3,289 Answers
It could be a battery issue - but that isn't likely. Disconnect the GPS from the car charger and connect to your computer via USB port overnight (8+ hours) and try again. The battery is "reconditioned" for lack of a better term, and will recharge again as in the past. If it happens again, repeat the procedure.
If still having problems, you should contact Garmin Support below:
http://www.garmin.com/garmin/cms/site/us/support
Please rate this reply if you found it helpful - good luck!
Posted on Jul 16, 2010
My TomTom,VIA 280 has suddenly stopped working. It is barely 2 years old. It will not power up
let it sit on the charger over night, check the charger on another device too.
Dec 08, 2014 | Tomtom GPS
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
Asus N81V series laptop won't turn on even when plugged in.
Its a power fault from the motherboard or a defective charger.
Jan 09, 2012 | ASUS Computers & Internet
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
My mio navman m300 will not turn on, its 2 months old and was working fine then suddenly would not turn on, its has not been dropped at all. any ideas??
hi,
Plug it and leave it on charge for at least 4-8h. Try both car charger and USB cable, it could be that the issue is the cable and not the battery
Nov 22, 2010 | Mio Moov M300 GPS for Europe 35" screen...
Not taking a charge
could be a few problems or just a single one.
I will suggest the simple one first.... get a new battery
they shouold last 2-3 years but seldom do because of the way people use(abuse) them ALL gps should be charged fully on an AC charger and run in the car on the DC powere AFTER the engine has been started. remove plug when stopping the engine to do shopping and only reconnect it whenh the engine is again running. doing this prevents battery shock and protects the SIIRF chip from damage by spikes. the siirc chip is what connect to sattelites for you.
If when connected to the AC chareger for 10 minutes you can turn it on ( whilst still connjected to charger) and program it that willo confirm that the battery is the culprit.If you cannot
get display and function whilst on charger then the problem is serious and also expensive to repair.
Jun 22, 2009 | Navigon 2100 Portable GPS Receiver
Garmin Stopped working altogether
Try connecting the GPS to your computer with the included USB cable. If it charges this way then you can assume that the Charger is defective.
Garmin will fix or replace a defective GPS within the first year. Go to http://www.garmin.com then click on the support tab. You can follow the menu selections to obtain warranty support.
Apr 05, 2009 | Garmin nuvi 750 GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Nuvi 200
Do you have a garmin home charger.
To do a test , is that working when you connect your unit with the car charger.
Less than 0.9 % of the units has a battery problem. I don't think you have one.
When it's full charge , what is the maximum bars you get ?
Dec 09, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
284 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
