How do I clean a thermstat - Office Equipment & Supplies
    President:
  • 1,561 Answers
Here's how to check a thermostat's accuracy and clean it if necessary:
Step 1: Tape glass tube thermometer to wall a few inches away from thermostat. Pad thermometer with paper towel to prevent it from touching wall. Make sure neither thermometer nor thermostat is affected by any outside temperature influences. In some homes, hole in wall behind thermostat through which wires enter is too large, allowing cold air to reach thermostat and affect its reading.
Step 2: Wait about 15 minutes for mercury to stabilize. Then compare reading on thermometer with reading of thermostat needle.
Step 3: If variation is more than a degree, check to see if thermostat is dirty. To examine thermostat, remove faceplate, usually held by a snap or friction catch. Blow away any dust inside it. Do not use a vacuum cleaner; its suction is too great. If thermostat has accessible contact points, rub new dollar bill between them to clean these spots. Do not use sandpaper or emery cloth. If element is coiled, use soft brush for cleaning.
Step 4: If thermostat has mercury vial inside, use level to make sure unit is straight. If thermostat is not straight, loosen mounting screws and adjust thermostat until it is level. Then retighten screws.
Step 5: After cleaning thermostat, check it again with glass thermometer, as detailed in Steps 1 and 2.
If thermostat is still not calibrated properly, it should be replace.
Take care.
Posted on Jul 15, 2010
When thermostat is stuck cold does that effect my exhaust cleaning mode? how do i change my thermostat?
trace upper radiator hose to thermostat housing, remove thermstat housing and thermostat, replace reverse of removal.
Dec 13, 2013 | 2008 Ford F 250 Super Duty 4WD
Can't install this thermstat .noma 52-2542-4
Copy following link to identify possible product manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#Noma-Garrison
Add a comment and say if you have problem with wiring, or programming, or operation, and what the thermostat controls, and add what information applies in manual.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 24, 2012 | Hardware & Accessories
Toyota 4 wheel drive engine overheating
CHECK THERMSTAT REMOVE PUT INTO BOILNG WATER AND IF IT
STAYS CLOSED THATS YOUR PROBLEM
Oct 19, 2012 | 1996 Toyota Land Cruiser
Temperature gage is going into red zone
YOU MAY HAVE A THERMSTAT IS THE STUCK PARTIALLY CLOSE
NOT ALLOWING FULL FLOW OF COOLANT THROUGHOUT ENGINE, TRY TO REPLACE THE THERMSTAT. WHAT ENGINE IS IT? 4.3L,5,7L ?
Oct 07, 2012 | 2003 GMC Envoy
It overheats when the ac is on already replaced the thermstate
Have the radiator cleaned bu a radiator shop, commonly called a rod out. Or just replace it with a new one which are really cheap.
Jul 27, 2012 | 1999 Dodge Durango
How do you adjust a digital thermstat to match a
You will have to buy either anew thermostat or a digital thermometer. I have been down this road many of times. You might try to make sure the back of the thermostat is insulated and not picking up a additional heat source.
Jun 14, 2010 | Heating & Cooling
Thermstate location
Hope this helps. It is on the end of the cylinder head where the big hose is going in.. :-)
Jun 01, 2010 | 1995 Ford Aspire
How to check thermstat pop off valve starts
you might want to check the water pressure going into the unit, it should only be no more then 75lbs anything over that will make the top pressure valve blow off
Jun 27, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Intertherm e3eb020h electric furnance won't start just hums
it was the thermstat i replaced the thermstat
thank you
Dec 03, 2008 | Heating & Cooling
14 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
