Question about Nokia N73 Cellular Phone
How to know our phone was going to be tapping?
  • 206 Answers
If it is done at the operator level then u can't come to know that it is being tapped!! it it is monitored by any spy ware in your phone then u can keep pressing the menu key and see if any program like spy caller is running in background if yes then ur calls may be recorded in the phone itself and can be heard by the person who installed it on to your phone with the password!
reply and rate!
Posted on Jul 15, 2010
Testimonial: " i thought that mobile tapping somewhat easy to know.but itwas cleared by ur support . so many people are suspecting when disturbance in incoming call. so thanks."
I need my phone monthly minutes
Go to phone dialer. Tap logs. Tap number you want to know about. Tap menu again. Then View Contact. There is a history tap, tap that.
Aug 01, 2017 | Cell Phones
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
I tapped phone and it magnified. How do I
Tap it again or double tap. If it still won't change go to settings + display + accessibility. There's an option to change zoom level or disable magnification. If this helped you fix the problem please let me know by clicking on the green tag below. Or send reply/comment if you require further assistance.
Thanks & Good luck!!!
May 30, 2015 | Cell Phones
Lg optimus logic low system memory
Only some apps can be moved to the card. Here's how to check and move the ones that can along with some other tips for freeing up space in internal storage:
1.Go to the Home screen. Press Menu and tap Settings , then Applications, then All
2. Tap each app and tap "Clear Cache". Tap "Move to SD Card" if it's not grayed out.
3. If there are any apps that you've downloaded and don't use uninstall them. The phone won't let you uninstall system apps that are essential to the phone's operation. If you aren't sure if you need an app or not install ES File Manager (which can be moved to the card) and use it to back up the app to the memory card before deleting.
4. Open Messaging, if you have any picture messages, tap on the bubble containing the picture. Tap Save attachment. After the picture has been saved, tap on the bubble again and tap Delete message. Also delete any text messages you don't need.
5. If you use Gmail, open Gmail, tap Menu, then tap Go to labels, then Trash and delete everything in Trash. If you use a different email app delete everything in its trash folder.
6. Launch the Camera, press the Menu button, tap settings and make sure that "Storage Location" is set to "SD Card".
Feb 01, 2014 | Straight Talk LG Optimus Logic Cell Phone
Mobile network settings
Hi
To input settings/choose from presets...
Press Menu Button (The one with four small squares on it)Go through menu and tap "Settings"
Tap "Wireless and Networks"
Scroll to and tap "Mobile Networks"
Tap on "Access Point Names/APN's"
If your Network is not listed press
The Menu Button again (Four Small Squares)
and tap "New Apn"
You will obviously need the settings.
You can probably find these on your network providers website.
Most Service Providers offer a text setup service.
This will send a text message to your phone which you read and delete, then restart your phone and settings should be set up automatically.
Check your Networks website to see if this service is available.
I hope this helps!?!
Mar 10, 2012 | Sony Ericsson XPERIA X10 Cell Phone
I forgot my security code, what should i do? i want to format my lg gd510 phone but it need security code and i dont know whats the code
BEFORE COMPLETING A RESET, BACKUP ANYTHING YOU HAVE STORED ON THE HANDSET, THIS INCLUDES CONTACTS *
  1. Tap the menu icon : :
  2. On the Settings section tap Phone settings
  3. Tap Reset settings
  4. Tap Yes to the question All settings will be reset. Continue?
  5. Enter the security code 0000 then tap OK
If you wish to delete the phones menory of all your images, music, contacts etc then,
  1. Tap the Menu icon : :
  2. On the Settings section, tap Phone settings
  3. Tap Memory info
  4. Tap Handset common memory
  5. Tap Reset
  6. Tap Yes to the question Do you want to delete licenses also?
  7. Tap Yes to the question All data will be cleared Continue?
  8. Enter the security code 0000 and tap OK.
Hope this help and if helpful RATE please.
Mar 10, 2011 | LG GD510 Cell Phone
I feel someone is tapping my phone.
No there is no facilty to tap an phone what evr high profile model you use.
Jul 22, 2010 | Nokia Cell Phones
My wife has just got a Samsung C3050 and wants to know how to turn of the key tones, also how to get a different tone notifying receipt of a text. She has swapped it for a C300 and is frustrated that the...
I know this post is late, however if you tap on menu, then settings then sound profile, then tap on the profile she is using (usually 'Normal') and maneuver to the bottom of the screen and tap on 'Volume and vibration' and go down to 'touch tone' and slide it to '0' then the key sound will stop. I hope this helps
Feb 06, 2010 | Samsung C3050 Cell Phone
I HAVE DOWNLOAD A I PHONE THEME FORHTC P3400I BUT HOW TO INSTALL
You need to extract the files from the downloaded winzip file first and then tap it in your phone. After that go to Start >> Settings >> Today in your phone and the theme would be displayed there, select that and tap Ok. All done.
You may also extract the theme file from the downloaded file on your computer and then transfer it on the phone, tap it, go to Today and apply the theme. Please rate the solution and in case you are still unable to apply the theme, please leave a comment and I shall help you further.
Aug 04, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Nokia N73 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
