Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
The electric brake does not come on all the time. How can I fix this?
  • 2,100 Answers
You have 2 possible places to fix, the switch is the first place, you could try taking the handle off and blowing it out with an air line, If not it will need replacing, I gave up on mine, If I whack it with a piece of wood, it will work.
And the next spot is the brushes, the electric brakes eats the brushes up by reversing the motor for a second, so check them too. Hope this helps.
Posted on Jul 15, 2010
All three brake lights went out at the same time on my 2006 cadillac cts found 15 amp blown fuse in rear fuse box. Replaced twice and as soon as we push on brake pedal fuse blew again.
You have a dead short to ground somewhere on the feed circuit to the brake lights . Your best bet ,take it to a automotive electric shop. Or search finding electrical short on youtube ,an try your hand at fixing it yourself.
Aug 29, 2017 | Cadillac Cars & Trucks
Brake light issue
I believe it deserves mention here that about 98% of all brake light malfunctions do not have anything to do with a blown fuse. In fact, fuses are NOT the CAUSE of electrical circuit malfunctions at all. Electrical circuit malfunctions cause fuses to blow. It is very important when diagnosing electrical circuits, that you understand this basic "cause and effect", so you do not waste time and effort looking for the wrong source of the problem. If there is a blown fuse involved in your brake light problem, you need to find out WHY. Simply replacing a blown fuse will not fix the problem that caused the fuse to blow and will only result in another blown fuse.
With that said, the fuse that protects your brake lamp circuits is Fuse 6B (20 Amp) in the instrument panel fuse block.
HINT: This fuse also protects your hazzard flasher circuits. If these work (front or rear or both) the fuse is not blown.
Jun 02, 2012 | 1994 Buick LeSabre
Suzuki gs500e all electrics work exept both brake lights how do i fix it
Electrical issues are difficult to fix in general. I have a Suzuki GSX-F Katana which has similar electrical mapping. When I was fixing my brake lights, I found the connection underneath the rear faring behind the seat. You'll need to make sure those wires are there, undamaged, and connected. Otherwise locate the fuse box and make sure the fuse for the rear brakes is still good. If you like my solution please feel free to give me a thumbs up!
May 03, 2011 | Suzuki GS 500 E Motorcycles
Wwe have a pronto m41 mobility chair.the service indicator light is telling me its a right brake problem can i fix this and how. also the led lights are chasing left to right. i have to get this working...
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Dec 23, 2010 | Electric Mobility Invacare Pronto M41...
I canot pull the lever to disengage to a free wheel
Your brake my be locked up due to corrosion . Take scooter and tilt it up so you can see under it and take spraw lube and spray where the lever goes into the brake assy then work up down or back and forth and it should lossen up
Mar 02, 2010 | Health & Beauty
Light brake is on how can i fix that problem
Get ur electrical cables check first.
Sep 13, 2009 | 1996 Chevrolet Blazer
I have a GIANT LA FREE SPORT ELECTRIC BIKE. THE BRAKE CABLES HAVE BEEN PULLED OUT AND THE MOTOR WONT TURN ON. THE BATTERY IS CHARGED AND THE LIGHTS GO ON. WHERE CAN I GET BRAKE CABLES OR BRAKE SWITCHES? DO...
The brake handles have each have a switch button that must be pressed for the motor to work. (Actually what happens is that when you pull the break lever it unpresses the button so the motor won't work against the brakes). Just tape the switch down for the time being. Electric Bikes Northwest and David Hawkins might be able to help you with bike parts. I've gotten some parts from him for my La Free Sport. Very few bike shops know anything about these bikes. Good Luck! Dennis
Jun 19, 2009 | Electric Bicycle Motor, Bike,electric...
Engine sputters when clutch/brake engaged; revs when brake only engaged
check under dash where pedals are as there may be wiring there that the pedals are touching and shorting out
Jun 02, 2009 | 1998 Jeep Wrangler
1993 Buick Regal the brake light and the anti lock brake lights
Electrical issues because that yr of buick well all yrs are **** cars and require more main than a girlfriend....Dont worry about it...But if u want to fix change the turn signal switch....:)
Answered by GARY KNOWS ALL
Jan 21, 2009 | 1998 Buick Park Avenue
Hitch installation w/electrical wiring for brake
Disconnect all that trailer connector mess and start over. Someone messed up. Do you have a 6- or 7- way RV connector, a 4- or 5-way flat (U-Haul) connector, or what? Was an electric brake box installed under the dashboard for trailer electric brakes?
Better yet, sell me your Jeep cheap, it probably can't be fixed, and it's worthless.
Jul 30, 2008 | 2000 Jeep Grand Cherokee
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
252 people viewed this question
Top Makita Saws Experts
mikenearman
ray gallant
Marvin
Marvin
Are you a Makita Saw Expert? Answer questions, earn points and help others
