Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Hot laptop and battery charger
I have a Amilo laptop and the cable connected to the mains supply,attached to it looks like the battery charger. This is getting very hot after only a few mins as well as my laptop. The laptop is only just over 2 years old
  • 122 Answers
It may well be that the battery that's being charged is getting past its sell by date. They only last for so many charges. easy way to find out is remove the battery, connect the power supply, and if the charger power supply doesn't get hot (usual to get warm) then its your battery. It is perfectly okay to use the laptop without the battery installed on the mains.
Posted on Jul 15, 2010
No power / start
Is the battery connected? If so, remove the battery and try powering up just on mains power. This may then start okay.
Nov 06, 2013 | Fujitsu AMILO PC Laptops
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
Booting up issue
Does it do this with the mains charger connected or only on battery power?
The plugging in the mains charger if not already, wait a couple of minutes and then try switching it on.
If the boots up fine you more than likely have a battery problem.
If it still doesn't start then you either have a power supply problem on the laptop itself or your main charger is faulty and not charging the battery.
You can also remove the battery and try booting it with only the mains charger connect.
Please provide the results of these queries
Mar 19, 2012 | Acer eMachines 520-2890 Notebook
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Power pin
I've found instructions with a diagram about how to open it up (for a memory upgrade). The directions are in German, but the pictures should still be useful.
http://www.amilo-forum.de/topic,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
Basically, the directions
1. Shutdown the laptop, turn offthe main source on the wall, unplug and
disconnect the power supply fromthe laptop.
2. Discharge yourself by touchingthe unpainted part of a PC or a radiator.
3. Remove the battery from thelaptop. (Shift the battery lock and pull
battery pack out.)
4. Remove the control Panel (usea razor or a flat butter knife ) push the
knife downward gentle and tilt itabout 30
o
outward to release clips and
left panel. Repeat the process onthe other side till the entire panel is
freely removed
5. Remove the panel to expose thesingle screw that secures the keyboard.
6. undo the screw to free thekeyboard and lift the Keyboard gently
7. Undo the clip that holds thekeyboard connector Ribbon in place this
would completely free thekeyboard. Remove the Keyboard. To unveil a
metal plate
Nov 10, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo Por 2055 DEAD
Try powering from the mains and see if your battery is being fully charged.
Aug 13, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu-Siemens - Batteries won't charge
Whats the spec of your power supply (approx 19v dc @ 3 - 4 Amps...)
Voltage 'OFF LOAD' is irrelevant - its the power consumption (A) that you need to validate (Do not measure directly)
Does the Laptop power up under mains feed ?
Is your concern mainly the fact that the battery(s) are not charging ?
Mar 30, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Faulty power connector to Amilo 1650
Please whe you change the battery and it does not solve the problem try replacing the "brick" probably the "brick" is not doing its job properly.
Dec 03, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
431 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
