Question about HP Laserjet CM2320nf All-In-One Color Printer
Hp cm2330 remove shipping lock - HP Laserjet CM2320nf All-In-One Color Printer
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
HP Color LaserJet CM 1312 Series MFP customers may experience a failure during initial printer startup. After installing the print cartridges and powering on the printer they may receive an error condition or error message on the printer’s display. The printer’s orange Attention LED will flash and a Remove shipping lock from XX cartridge message will appear on the printer’s display; where XX represents the black, cyan, magenta or yellow print cartridge or any combination.
SOLUTION: First, verify the print cartridge shipping locks (orange ring attached to the toner as shown below) have been removed from the print cartridge(s) in question. Second, verify the front and back doors of the printer are properly closed. If the shipping lock has been removed, all doors are closed, and the Remove shipping lock from XX cartridge error remains a unit exchange is the recommended solution.
Contact Hewlett-Packard Customer Support. Refer to your warranty/ support documentation for the number to call in your area. Refer to this document’s number (c01677135) with your customer service representative.
Hp tech support phone for this model # : 1 800 334 51 44
Or you can take the printer to an HP Authorized Repair Center, heres a link will help you find one near your location:
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can contact me directly on:
eliteprintersolutions@gmail.com
Posted on Jul 15, 2010
  • 1 more comment
  • susankb66 Feb 26, 2011
    We have had this problem with two of these printers now, each less than a year old. It is the most frustrating issue. They replaced the first one under warranty and will now need to replace this one. I will never buy an HP printer again.
  • Jansin Sep 19, 2012
    The problme is not the printer, the cartridges are defective. Replaced them 3 times and the 3rd cartridge worked.
    The problem is not with the printer, the cartridges are defective. Returned them 3 times and the 3rd one worked.
Some cartridges have a defective plate. There is a black plastic plate screwed on to the cartridge, with copper contacts, usually on the left hand side of the cartridge. If you still have your old working cartridge, swap this plate with the old one and your new cartridge should work fine. You will need a Philips screw driver to remove the two screws, also it might help to wrap a rubber band around the cartridge, or hold it tight in your hand so the cartridge doesn't split apart when you remove the plate, as this plate holds the roller and the top and bottom covers together. The printer may still show low toner, thinking the old cartridge is in, but ignore it and continue printing.
Posted on Sep 19, 2012
Getting an error message
If this is a color printer, there are cartridge locks on the left side of the printer after you remove the cartridges especially on a 3600, 3800, etc. These white plastic locks can break and you will get this message. But first make sure the shipping tape etc are removed from the cartridge
Jul 31, 2014 | HP LaserJet Office Equipment & Supplies
Hp cp2025 remove shipping lock
I had same problem with black and blue cartridges. I did all recommendations -- return to factory setting ( no help). Shake cartridges REALLY hard ( no help); reinstall printer/ driver ( no help). What finally WORKED was SWAPPING the cartridges around ( for ex. put red in black spot, blue in yellow). I then got an error message ( b/c in wrong spot). Then I placed them back in correct spots and it WORKED !!! NO more error message that the ship lock was on !!! And this worked with generic cartirdges.
Nov 19, 2011 | HP Laserjet Cp2025n Printer
10.94.00 error remove shipping lock in hp lj 4515 printer
Open the ink cartridge cover and remove the paper or plastic shipping retainer on the bar holding the ink cartridges in place. If the ink cartridges are pre installed, lift them out and check that the plastic tape is removed from the gold contact and print head.
Apr 15, 2011 | Office Equipment & Supplies
Hi, my printer just keep saying that ( remove shipping lock ) and i just replaced the cartridge . please i need help
Have you removed the clear tape that seals the unit for shipping? If not - with the cartridge in the printer, find the tape (LHS) and pull it directly up. If you have already removed it - take out the cartridge, manually wind the rollers a little and then replace it. (THis worked for me!)
Dec 11, 2010 | HP LaserJet CP1515n Printer
HP 2320 problem
For Every New Catridge there is lock on catridge head u must remove to use the catridge...take out the catridge then remove the shipping seal or lock. refer instruction printed on catridge cover.
Jul 07, 2009 | Office Equipment & Supplies
Deskjet HP 6122 Printer carthridge locked.
Reach in with a looong screwdriver and push the white block down.
Mar 01, 2009 | HP DeskJet 6122 InkJet Printer
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
HP Laserjet CM2320nf All-In-One Color Printer Logo
3,103 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
