Apple iPhone Smartphone Logo
A
Anonymous Posted on Jul 01, 2010
Hi i have a apple iphone and i put a passcode on it so my kids dont get into it and now i cant remember teh code i tried to many times and now my phone is disabled and it said connect to itunes and i did that and i still cant get it to work and i cant use it at all and its for emergency calls only can you please help me
Anonymous
Level 1:
Problem Solver:
  • Contributor 35 Answers
  • Posted on Aug 08, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
35
Questions
0
Helped
3521
Points
40
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Jul 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
15836
Points
59
Perform a restore via iTunes. That will reset everything. Then resync to get everything back to your iPhone.
3answers
How to bypass iPhone 4 icloud passcode
iCloud password should be the same passwords as your apple id
1helpful
I had purchased an Apple iphone5 in the year March - 2013. The model no. is A-1492 and the Serial No. is 990002850115930. I had then recently downloaded ios7 operating system in my iphone5. During the...
You will need to restore the iphone in itunes and with iOS 7 you dont need to put a passcode on you just bypass and say no code
you will be able to get it to connect to itunes by putting the iPhoe in DFU mode.
here is how you do it
open itunes and plug your usb cord into the computer.
plug the usb cord into the iphone.
turn the iphone off
now, hold the power button and the home button down for 10 seconds. count it out. the phone will go black. after 10 seconds let go of the power button and continue to hold the home button for 20-25 seconds. you will see the phone pop up on itunes in recovery mode.
click the summary tab and press restore.
once the phone restores it will come to the activation process.
if you can get your itunes account info then go through the process and enter the information. don't put a passcode on. you dont have to.
if you have your itunes info you can accept the activation and restore the iphone from an icloud backup or just start new
Put in wrong password on the phone too many times, now i cant log in to my google acct on it either, its just stuck at the same spot
What Brand and Type of phone ??..
Phone password or google account password ??..
Im thinking iphone ?
Although a passcode limits your iPhone to authorized use only, protecting your vital personal information, if you forget it, you can't use your phone until you enter the correct code or revert your phone to the default factory status.
Apple provides ways to resolve a forgotten passcode problem and improve the iPhone's security.
Wrong Passcode
When you enable iPhone passcode security, the phone requires you to enter the code to display the home screen.
By default, when this protection feature is enabled, you'll be prompted to enter the passcode to turn on or restart the iPhone, wake it or unlock the screen.
When you enter the wrong passcode, the "Wrong Passcode try again" message appears onscreen.
If you enter the incorrect code too many times, the iPhone will lock automatically and display the "iPhone is disabled, try again in 1 minute" message.
This disabling security feature is designed to protect it from unauthorized tampering.
If you keep entering the incorrect code, the iPhone will be disabled for a longer time.
Restoring iPhone
If you don't remember your passcode, unfortunately, there is no way to retrieve it.
Apple says that the only way to solve passcode problems is to restore the iPhone with iTunes.
Before restoring the phone, downloading and installing the latest version of iTunes will improve connection and decrease the chances of errors.
Unfortunately, restoring the iPhone erases saved content and clears custom settings, so create a backup copy of your files with iTunes before proceeding.
From there, you can restore your iPhone by clicking the "Restore" button on the device's "Summary" tab in iTunes.
When the process completes, you can change the passcode settings.
Changing Passcode Settings
iPhone allows you to not only create a new passcode, but specify the amount of time it should take before the screen locks after inactivity.
You can also specify whether you want to use a simple four-digit passcode or a longer one that can include letters and numbers.
Tapping the "Settings" icon on the home screen will bring up the phone's settings.
From there, tapping "General" and then tapping "Passcode Lock" will bring up the "Passcode Lock" customization screen.
Select the settings you want to use to protect your iPhone. The changes will take effect immediately or when the iPhone turns off.
Tips
After restoring your iPhone, create a passcode you'll remember easily.
While creating a longer passcode can increase the security on your phone, you can forget it easily if you don't write it down and store it in a safe place.
gmail password reset
Open the Web browser on your phone and navigate to gmail.com.
Tap "Can't access your account" located under the "Sign in" button.
Select "I forgot my password" and then click "Reset your password here."
Type your email into the "Email" text box and then type the random captcha into the captcha text box.
An email with your new Gmail password will be sent to your alternate Gmail address.
Follow the directions in the email to reset your password.
Type the new Gmail password into the loin screen on your Droid to unlock the account.
http://www.gmail.com/
2answers
How to open my iphone if i forgot the passcode.?
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. You can try plugging it into iTunes to see if it reboots itself
2helpful
Need to change iphone passlock code
http://osxdaily.com/2011/01/16/forgot-iphone-passcode-how-to-reset/
this will help you!
nouvelle tablette pc
7helpful
3answers
I forgot my restriction code for my ipod touch
If you really can't remember your passcode, the your last resort is to restore your iPod touch. but before that, you should put it to recovery mode first.
For step by step instruction, click here.
Click here for more iPod touch / iPhone tips.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
